Spatial Column Problems with PL/SQL Developer 9
CTAMike
BUG: Querying a Spatial column returns "Error while trying to retrieve text for error ORA-21500" in PL/SQL Developer 9.0.6.1665. This worked in PL/SQL Developer 8, it would simply break down the SHAPE field into fields as follows:
SHAPE.SDO_GTYPE
SHAPE.SDO_SRID
SHAPE.SDO_POINT.X
SHAPE.SDO_POINT.Y
SHAPE.SDO_POINT.Z
SHAPE.SDO_ELEM_INFO
SHAPE.SDO_ORDINATES
I also highly suggest working on incoperating GeoRaptor into the PL/SQL Developer engine.
http://sourceforge.net/apps/mediawiki/georaptor/index.php?title=Main_Page
Thanks in advance!
--Mike
CREATE TABLE BUSOPS_K_ZONES2 (
DIST NUMBER,
REGION VARCHAR2(12),
DIST_TEXT VARCHAR2(5),
SHAPE_AREA NUMBER,
SHAPE_LEN NUMBER,
SHAPE MDSYS.SDO_GEOMETRY);
INSERT INTO USER_SDO_GEOM_METADATA (TABLE_NAME, COLUMN_NAME, DIMINFO, SRID)
VALUES ('BUSOPS_K_ZONES2', 'SHAPE',
MDSYS.SDO_DIM_ARRAY
(MDSYS.SDO_DIM_ELEMENT('X', -88.000000000, -87.000000000, 0.010000000),
MDSYS.SDO_DIM_ELEMENT('Y', 41.500000000, 42.100000000, 0.010000000)
8307);
COMMIT;
SELECT * FROM BUSOPS_K_ZONES2; --Fails "Error while trying to retrieve text for error ORA-21500
SELECT DIST, REGION, DIST_TEXT, SHAPE_AREA, SHAPE_LEN
FROM BUSOPS_K_ZONES2; --OK
SELECT SHAPE FROM BUSOPS_K_ZONES2; --Fails "Error while trying to retrieve text for error ORA-21500
