Rob van Rijen
Hi
I have mentioned this earlier, but I'd really like this to be fixed.
Throughout all windows in PLSD you can use the ctrl-insert and shift-insert combinations to copy and paste from the clipboard.
All windows... except the large data editor. In that window the ctrl-insert does not work (the shift-insert *does* btw)
I know I can assign my own keyboard shortcuts, but these key combinations are standard windows shortcuts and should be supported by default imo.
In case you're wondering why I use those instead of ctrl-c & v... I'm a left-handed mouse user and the shift/ctrl-insert keys are easier to use with the right hand
Thanks in advance!
Rob
Thanks in advance!
Rob
