R RobertG Member² May 3, 2010 #1 Hi, On one particular PC the shortcut keys do not work. When I set in preferences--Key configuration, I set F10 to open new SQL Window. The setting is saved but when I press F10 nothing happens. Any ideas anyone ? Thanks Robert
Marco Kalter Administrator Staff member May 4, 2010 #1 This works fine for me. Can you let me know which PL/SQL Developer version you are using?
R RobertG Member² May 4, 2010 #1 Hi, We are using version 8.0.2.1505 This is a network installation, it works for all developers except for one. Thanks Robert
R RobertG Member² May 4, 2010 #1 Hi, We found the problem, he had a default.ini file and a default_original.ini file and it seems that PL/SQL was showing default.ini in the preferences but was actually using the default_original.ini file for the PFKeys. Thanks Robert
