setting main connection and pinning sessions
frido
I am currently testing version 10.0.3.1701
I am using lots of different connections, so focus on connections. Nice extension by the way (-: didn't give version 9 a try, so lots of new stuff here
Problem 1
When I double click on a connection in window connections, the main connection is changed. But all existing windows keep their "old" connection. Doesn't matter if they are pinned or not. I think it worked the first minutes, but then it stopped working. reinstall didn't make it better.
Problem 2
As a workaround I try to reconnect all windows to the new main connection --> not possible, because grey. It is only black, when that connection is active and NOT the main connection. Why is the option greyed out ?
Remark: It is quite hard to find a connection (probably closing unused connections makes it even worse), where reconnect all windows is not grey ... As the reconnect ignores, if the window is pinned or not (bug or feature?), it shouldn't be grey. Similar problems also with menu . No idea in which case it is active and when grey )-:
wish
I would appreciate a more popular place to show the main connection in title bar. Ok, it's bold in the connection window, but would be nice to have an indicator also in the objects window. I am using different colors for different connections, may be it's possible to add the color of the main connection somewhere
Regards
Christian
Problem 2 was sitting in front of the computer ....
I thought, that all connections from all different logins will be redirected to one target database. But "only" connections from one login will be redirected to a different one
--> working
