Select word using Shift Ctrl Right Arrow
I used to be able to select a word by pressing Shift+Ctrl+Right Arrow in the SQL Window or in Program Window. Now this is only possible in a Command Window.
Do you know if this is a bug or if I can set this somehow in Preferences. I searched in Preferences > Key Configuration but didn't find anything close.
Thanx,
Petros
Sorry,
I have just found out that I needed to reset all the values in Key Configuaration to the default ones. Somehow all the values were erased.
Petros
