Scan SQL to retrive variables in runtime
Morff
Hi
In variables editor there is a "Scan SQL" button which fills variables collection from sql command. I need create variables automatically after append sql command to oracledataset. How can I do that.
In the Oracle unit there is a published function like this:
function FindVariables(const SQL: string; IncludeDuplicates: Boolean): TStringList;
This function will scan the SQL parameter for variables and will return them in a TStringList. The IncludeDuplicates parameter determines if duplicate variables will be included or not.
I thought it can be:
OracleDataSet.sql.append(memo1.text);
// oracledataset.RetrieveVariables or oracledataset.Parse or something like that
if OracleDataSet.Variables.count > 0 then
// Show value list editor with variables
but FindVariables can help
Thanks a lot.
