G gshari23 Member² Apr 12, 2013 #1 If i break my debug in the middle of debugging session plsql is getting hanged. I am unable to perform any other operations. Kindly help on this.
B Benjamin L Member² Apr 12, 2013 #1 This problem already existed in v9, but in v10 it occures more frequently. Sometimes you can use PSD after a few seconds. But mostly you can only Kill PSD by task manager and start again.
G Gustavo Member³ Apr 12, 2013 #1 I only had this issue when running agains an Oracle RAC instance. In that case, you should modify TNSNAMES to connect to a specific cluster.
G gshari23 Member² Apr 20, 2013 #1 Can u help me in detail..I am not getting it ..If i use Step over in debug it is getting hanged
G Gustavo Member³ May 9, 2013 #1 Your DBA should be able to help you better than I would. You just need a TNS entry that connects to a single Cluster.
