Reg: problem during debug
gshari23
If i break my debug in the middle of debugging session plsql is getting hanged. I am unable to perform any other operations. Kindly help on this
PL/SQL Developer
Version 7.1.5.1398
Windows 2003 Enterprise Edition (64-bit) 5.2 Build 3790 (Service Pack 2)
Physical memory : 4,194,304 kB (4,194,304 available)
Virtual memory : 2,097,024 kB (2,002,720 available)
Parameters
C:\PLSQLDEVELOPER\plsqldev.exe
DebugSQL
Preferences
Session mode: Multi
OCI Library:
Use OCI7: False
Preference Files
Plug-Ins
4/18/2013 8:55:02 PM Application started
4/18/2013 8:55:02 PM InitPreferences
4/18/2013 8:55:02 PM Load C:\PLSQLDEVELOPER\Preferences\Default = 0
4/18/2013 8:55:02 PM PreferenceSet.Load C:\PLSQLDEVELOPER\Preferences\Default\Default.ini
4/18/2013 8:55:02 PM PreferenceSet.Load OK
4/18/2013 8:55:02 PM Determine LocalPrefPath
4/18/2013 8:55:02 PM [1]: C:\PLSQLDEVELOPER\Preferences
4/18/2013 8:55:02 PM LocalPrefPath: C:\PLSQLDEVELOPER\Preferences\119060
4/18/2013 8:55:02 PM Load C:\PLSQLDEVELOPER\Preferences\119060 = 0
4/18/2013 8:55:02 PM PreferenceSet.Load C:\PLSQLDEVELOPER\Preferences\119060\default.ini
4/18/2013 8:55:02 PM PreferenceSet.Load C:\PLSQLDEVELOPER\Preferences\119060\user.prefs
4/18/2013 8:55:02 PM InitPreferences end
4/18/2013 8:55:02 PM SortPreferenceSets
4/18/2013 8:55:02 PM - Default 119060
4/18/2013 8:55:02 PM - System Default
4/18/2013 8:55:02 PM pfReadRegistry(PL/SQL Developer\Shell\Open\Command, )
4/18/2013 8:55:02 PM ReadString OK
4/18/2013 8:55:02 PM pfReadRegistry: "C:\PLSQLDEVELOPER\plsqldev.exe" "%1"
4/18/2013 8:55:02 PM LoadPreferences
4/18/2013 8:55:02 PM LoadPreferences searching for default
4/18/2013 8:55:02 PM C:\PLSQLDEVELOPER\Preferences\119060\default.ini
4/18/2013 8:55:02 PM LoadPreferences NewPref := nil
4/18/2013 8:55:02 PM LoadPreferences Reading preferences
4/18/2013 8:55:02 PM LoadPreferences ReadPosition
4/18/2013 8:55:02 PM LoadPreferences ToolsBrowserItemClick(nil)
4/18/2013 8:55:02 PM LoadPreferences CreateBrowserFilters...
4/18/2013 8:55:02 PM LoadPreferences Files
4/18/2013 8:55:02 PM LoadPreferences Logon
4/18/2013 8:55:02 PM LoadPreferences Buttons
4/18/2013 8:55:02 PM LoadPreferences Printer
4/18/2013 8:55:02 PM LoadPreferences BrowserFolders
4/18/2013 8:55:02 PM LoadPreferences end
4/18/2013 8:55:02 PM MacroLibFilename: C:\PLSQLDEVELOPER\Macro\119060.lib
4/18/2013 8:55:08 PM TOracleSession PLSQLDevForm.Session Start Session.LogOn as PMOUSER@RPNET02
4/18/2013 8:55:08 PM TOracleQuery BytesPerCharacterQuery Start Query.Execute
4/18/2013 8:55:08 PM TOracleQuery BytesPerCharacterQuery End (1 record processed)
Duration = 0
Duration = 0
4/18/2013 8:55:08 PM TOracleQuery Query Start Query.Execute
4/18/2013 8:55:08 PM TOracleQuery Query End (1 record processed)
Duration = 0
4/18/2013 8:55:08 PM TOracleSession PLSQLDevForm.Session End
Duration = 0.25
4/18/2013 8:55:08 PM LogonHistorySave start
4/18/2013 8:55:08 PM ChangeUserPref LogonHistory,
4/18/2013 8:55:08 PM ChangeUserPref end
4/18/2013 8:55:08 PM ChangeUserPref DSA,
4/18/2013 8:55:08 PM ChangeUserPref ColumnAssociations,
4/18/2013 8:55:08 PM ChangeUserPref ImportAssociations,
4/18/2013 8:55:08 PM ChangeUserPref BrowserFilters,
4/18/2013 8:55:08 PM ChangeUserPref BrowserFolders,
4/18/2013 8:55:08 PM ChangeUserPref SessionQueries,
4/18/2013 8:55:08 PM ChangeUserPref ExternalTools,
4/18/2013 8:55:08 PM ChangeUserPref Documents,
4/18/2013 8:55:08 PM ChangeUserPref Reports,
4/18/2013 8:55:08 PM PreferenceSet.Save
4/18/2013 8:55:08 PM PreferenceSet filename = C:\PLSQLDEVELOPER\Preferences\119060\user.prefs
4/18/2013 8:55:08 PM PreferenceSet.Save end
4/18/2013 8:55:08 PM LogonHistorySave end
4/18/2013 8:55:08 PM FormCreate Session.Connected
4/18/2013 8:55:08 PM FormCreate Logon.Executed -1
4/18/2013 8:55:08 PM FormCreate TDBNames.Make
4/18/2013 8:55:08 PM FormCreate SessionChanged
SQL = select * from v$version
4/18/2013 8:55:08 PM TOracleQuery Query End (5 records processed)
Duration = 0
4/18/2013 8:55:08 PM SessionChanged SetDBAViews
4/18/2013 8:55:08 PM TOracleQuery $0418AD60 Start Query.Execute
4/18/2013 8:55:08 PM TOracleQuery $0418AD60 End (0 records processed)
Duration = 0
Duration = 0
4/18/2013 8:55:08 PM SessionChanged Authorizations.Load
4/18/2013 8:55:08 PM TOracleQuery $0418AC00 Start Query.Execute
sys.plsqldev_authorization
4/18/2013 8:55:08 PM TOracleQuery $0418AC00 End
Duration = 0
4/18/2013 8:55:08 PM SessionChanged EnableAuthorizedMenus
4/18/2013 8:55:08 PM TOracleSession $04A79A20 Start Session.LogOn as PMOUSER@RPNET02
Duration = 0
4/18/2013 8:55:08 PM TOracleSession $04A79A20 End
Duration = 0.047
4/18/2013 8:55:08 PM SetSessionAction starts: Main session
SQL = select null from dual
4/18/2013 8:55:08 PM TOracleQuery $0418AEC0 Start Query.Execute
from sys.user_objects o
4/18/2013 8:55:08 PM TOracleQuery $0418AD60 End (1 record processed)
Duration = 0
:ACTION = Main session
Duration = 0
4/18/2013 8:55:08 PM SetSessionAction ends
4/18/2013 8:55:08 PM ExecuteConnectScript starts
4/18/2013 8:55:08 PM ExecuteConnectScript ends
4/18/2013 8:55:08 PM TOracleQuery PLSQLDevForm.DynamicQuery Start Query.Execute
4/18/2013 8:55:08 PM TOracleQuery PLSQLDevForm.DynamicQuery End (1 record processed)
Duration = 0
4/18/2013 8:55:08 PM TOracleQuery $0418AEC0 End (100 records processed)
Duration = 0.016
4/18/2013 8:55:08 PM SessionChanged LoadRecentObjects
4/18/2013 8:55:08 PM TOracleQuery $0418AEC0 Start Query.Next for up to 100 records
4/18/2013 8:55:08 PM SessionChanged Notify children
Duration = 0
4/18/2013 8:55:08 PM SessionChanged Logoff secondary sessions
4/18/2013 8:55:08 PM SessionChanged SessionMode = smMulti
Duration = 0
4/18/2013 8:55:08 PM SessionChanged EnableChildFunctions
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
4/18/2013 8:55:09 PM TOracleQuery $0418AEC0 End (100 records processed)
Duration = 0.016
4/18/2013 8:55:09 PM SessionChanged
OracleHomeKey: SOFTWARE\ORACLE\KEY_OraClient11g_home1
OracleHomeDir: C:\app\119060\product\11.1.0\client_1
Found: oci.dll
Using: C:\app\119060\product\11.1.0\client_1\bin\oci.dll
4/18/2013 8:55:09 PM TOracleQuery $0418AEC0 Start Query.Next for up to 100 records
4/18/2013 8:55:09 PM TOracleQuery PLSQLDevForm.DynamicQuery Start Query.Execute
SQL = select value from sys.nls_database_parameters where parameter = 'NLS_CHARACTERSET'
Duration = 0
4/18/2013 8:55:09 PM TOracleQuery PLSQLDevForm.DynamicQuery End (1 record processed)
Duration = 0
Duration = 0
Duration = 0.015
4/18/2013 8:55:09 PM TOracleQuery $0418AEC0 End (66 records processed)
Duration = 0
4/18/2013 8:55:09 PM TOracleQuery $0418AEC0 Start Query.Execute
from all_synonyms s,
sys.all_objects o
and o.owner = s.table_owner
4/18/2013 8:55:09 PM SortPreferenceSets
4/18/2013 8:55:09 PM - Default 119060
4/18/2013 8:55:09 PM - System Default
4/18/2013 8:55:09 PM TOracleQuery $0418AAA0 Start Query.Execute
4/18/2013 8:55:09 PM TOracleQuery $0418AAA0 End (0 records processed)
Duration = 0
Duration = 0.016
4/18/2013 8:55:09 PM WMUpdatePopups starts
4/18/2013 8:55:09 PM GetCrashList: 196976.cfg
Duration = 0.219
4/18/2013 8:55:09 PM GetCrashList: 460278.cfg
4/18/2013 8:55:09 PM LoadDesktop starts
Duration = 0
4/18/2013 8:55:09 PM LoadDesktop ends
4/18/2013 8:55:09 PM WMUpdatePopups ends
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0.015
Duration = 0
Duration = 0
Duration = 0.016
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0.015
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0.016
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0.015
Duration = 0.032
Duration = 0.25
Duration = 0.047
Duration = 0.046
Duration = 0.016
Duration = 0
Duration = 0
Duration = 0.015
Duration = 0
Duration = 0
Duration = 0
Duration = 0.016
Duration = 0.015
Duration = 0
Duration = 0.016
Duration = 0.015
4/18/2013 8:55:09 PM TOracleQuery $0418AEC0 End (98 records processed)
Duration = 0.016
4/18/2013 8:55:09 PM TOracleSession $04A79A20 Start Session.LogOff
4/18/2013 8:55:09 PM TOracleSession $04A79A20 End
Duration = 0.016
4/18/2013 8:55:11 PM AddPlugInPopups Start 0
4/18/2013 8:55:11 PM AddPlugInPopups End
4/18/2013 8:55:13 PM AddPlugInPopups Start 0
4/18/2013 8:55:13 PM AddPlugInPopups End
4/18/2013 8:55:15 PM TOracleQuery PLSQLDevForm.ObjectQuery Start Query.Execute
SQL = select object_name, owner object_owner, status, object_type, created, last_ddl_time
from sys.all_objects o
where object_type = 'PACKAGE'
and object_name not like 'BIN$%'
order by decode(owner, user, 0, 1),
owner,
object_name
:OBJECT_TYPE = PACKAGE
:EXTRA_CONDITION =
4/18/2013 8:55:15 PM TOracleQuery PLSQLDevForm.ObjectQuery End (100 records processed)
Duration = 0.437
4/18/2013 8:55:15 PM TOracleQuery PLSQLDevForm.ObjectQuery Start Query.Next for up to 100 records
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
4/18/2013 8:55:15 PM TOracleQuery PLSQLDevForm.ObjectQuery End (10 records processed)
Duration = 0
4/18/2013 8:55:26 PM TOracleQuery $0418AAA0 Start Query.Execute
SQL = select debuginfo
from sys.all_probe_objects po
where po.owner = 'PMOUSER'
and po.object_name = 'PKG_PIPELINE'
and po.object_type = 'PACKAGE'
:OBJECT_OWNER = PMOUSER
:OBJECT_NAME = PKG_PIPELINE
4/18/2013 8:55:26 PM TOracleQuery $0418AAA0 End (1 record processed)
Duration = 0.141
4/18/2013 8:55:26 PM AddPlugInPopups Start 0
4/18/2013 8:55:26 PM AddPlugInPopups End
4/18/2013 8:55:28 PM TOracleQuery $0418AAA0 Start Query.Execute
4/18/2013 8:55:28 PM TOracleQuery $0418AAA0 End (1 record processed)
Duration = 0
4/18/2013 8:55:28 PM AddPlugInPopups Start 0
4/18/2013 8:55:28 PM AddPlugInPopups End
4/18/2013 8:55:29 PM TOracleQuery $0418AAA0 Start Query.Execute
and po.object_name = 'PKG_PIPELINE_NEW_UI'
:OBJECT_NAME = PKG_PIPELINE_NEW_UI
4/18/2013 8:55:29 PM TOracleQuery $0418AAA0 End (1 record processed)
Duration = 0.156
4/18/2013 8:55:29 PM AddPlugInPopups Start 0
4/18/2013 8:55:29 PM AddPlugInPopups End
4/18/2013 8:55:31 PM Create TProcEditForm Start
4/18/2013 8:55:31 PM Create TProcEditForm Inherited
4/18/2013 8:55:31 PM Create TProcEditForm SetupMainFont
4/18/2013 8:55:31 PM Create TProcEditForm Activate
4/18/2013 8:55:31 PM Create TProcEditForm Activate done
4/18/2013 8:55:31 PM Create TProcEditForm UpdateWindowList
4/18/2013 8:55:31 PM Create TProcEditForm Positioning
4/18/2013 8:55:31 PM Create TProcEditForm Finished
4/18/2013 8:55:31 PM TOracleQuery $0418AD60 Start Query.Execute
SQL = select text from sys.all_source
where owner = :owner
and name = :name
and type = :type
order by line
:OWNER = PMOUSER
:NAME = PKG_PIPELINE_NEW_UI
:TYPE = PACKAGE
4/18/2013 8:55:31 PM TOracleQuery $0418AD60 End (100 records processed)
Duration = 0.015
4/18/2013 8:55:31 PM TOracleQuery $0418AD60 Start Query.Next for up to 100 records
4/18/2013 8:55:31 PM TOracleQuery $0418AD60 End (60 records processed)
Duration = 0
4/18/2013 8:55:31 PM TOracleQuery PLSQLDevForm.ProgErrorQuery Start Query.Execute
SQL = select *
from sys.all_errors
where name = :name and type = :type and owner = :owner
order by sequence
:TYPE = PACKAGE
:OWNER = PMOUSER
4/18/2013 8:55:31 PM TOracleQuery PLSQLDevForm.ProgErrorQuery End (0 records processed)
Duration = 0
4/18/2013 8:55:31 PM ProcEditForm.GetTabNames
4/18/2013 8:55:31 PM + PKG_PIPELINE_NEW_UI
4/18/2013 8:55:31 PM ProcEditForm.GetTabNames done
4/18/2013 8:55:31 PM NavigationBookmarks.EnableButtons(Rebuild)
4/18/2013 8:55:31 PM NavigationBookmarks: Backward=0, Forward=0
4/18/2013 8:55:31 PM UpdateContents(Clear)
4/18/2013 8:55:31 PM Source = CREATE OR REPLACE PACKAGE PKG_PIPELINE_NEW_UI IS
4/18/2013 8:55:31 PM UpdatingContents: Thread Started
4/18/2013 8:55:31 PM ContentsThread: Execute
4/18/2013 8:55:31 PM ContentsThread: Analyze
4/18/2013 8:55:31 PM ContentsThread: Valid
SQL = select * from sys.all_objects
where object_type = :object_type
and owner = :object_owner
and object_name = :object_name
and :sub_object is null
:OBJECT_TYPE = PACKAGE BODY
:SUB_OBJECT = Null
4/18/2013 8:55:31 PM ContentsThread: Suspend started
4/18/2013 8:55:31 PM TOracleQuery $0418AD60 End (1 record processed)
Duration = 0
and name = :name
and type = :type
order by line
:OWNER = PMOUSER
:TYPE = PACKAGE BODY
Duration = 0.125
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
4/18/2013 8:55:31 PM TOracleQuery $0418AD60 End (44 records processed)
Duration = 0
and name = :name
and type = :type
order by line
:OWNER = PMOUSER
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
SQL = select *
from sys.all_errors
order by sequence
:OWNER = PMOUSER
Duration = 0
4/18/2013 8:55:31 PM Source = CREATE OR REPLACE PACKAGE BODY PKG_PIPELINE_NEW_UI IS
4/18/2013 8:55:31 PM ContentsThread: Resume
4/18/2013 8:55:31 PM ContentsUpdated
4/18/2013 8:55:31 PM ContentsUpdated: Valid
4/18/2013 8:55:31 PM ContentsUpdated: Refresh Code Contents
4/18/2013 8:55:38 PM AddNavigationBookmark starts
4/18/2013 8:55:38 PM AddNavigationBookmark GNV00001
4/18/2013 8:55:38 PM NavigationBookmarks.EnableButtons(Rebuild)
4/18/2013 8:55:38 PM NavigationBookmarks: Backward=1, Forward=0
4/18/2013 8:55:38 PM AddNavigationBookmark ends
4/18/2013 8:55:39 PM TOracleQuery $0418AD60 Start Query.Execute
4/18/2013 8:55:39 PM TOracleQuery $0418AD60 End (1 record processed)
Duration = 0
4/18/2013 8:55:39 PM TOracleQuery PLSQLDevForm.ResolveSymbolQuery Start Query.Execute
SQL = declare
t_owner varchar2(30);
t_name varchar2(30);
procedure check_mview is
dummy integer;
if :object_type = 'TABLE' then
select 1 into dummy
where owner = :object_owner
and object_type = 'MATERIALIZED VIEW'
and rownum = 1;
:object_type := 'MATERIALIZED VIEW';
end if;
exception
when others then null;
:sub_object := null;
if :deep != 0 then
if :part2 is null then
from sys.all_constraints c
where c.constraint_name = :part1 and c.owner = :cur_schema
and rownum = 1;
else
select constraint_type, owner, constraint_name, :part3
where c.constraint_name = :part2 and c.owner = :part1
and rownum = 1;
end if;
if :object_type = 'P' then :object_type := 'PRIMARY KEY'; end if;
if :object_type = 'U' then :object_type := 'UNIQUE KEY'; end if;
if :object_type = 'R' then :object_type := 'FOREIGN KEY'; end if;
if :object_type = 'C' then :object_type := 'CHECK CONSTRAINT'; end if;
return;
exception
when no_data_found then null;
end if;
:sub_object := :part2;
if (:part2 is null) or (:part1 != :cur_schema) then
select object_type, :cur_schema, :part1
where owner = :cur_schema
and object_name = :part1
and object_type in ('MATERIALIZED VIEW', 'TABLE', 'VIEW', 'SEQUENCE', 'PROCEDURE', 'FUNCTION', 'PACKAGE', 'TYPE', 'TRIGGER', 'SYNONYM')
and rownum = 1;
if :object_type = 'SYNONYM' then
select s.table_owner, s.table_name
into t_owner, t_name
from all_synonyms s
where s.synonym_name = :part1
and s.owner = :cur_schema
and rownum = 1;
select o.object_type, o.owner, o.object_name
where o.owner = t_owner
and o.object_name = t_name
and rownum = 1;
end if;
if :part3 is not null then
:sub_object := :sub_object || '.' || :part3;
end if;
check_mview;
return;
exception
end if;
from all_synonyms s
and s.owner = 'PUBLIC'
and rownum = 1;
and rownum = 1;
check_mview;
return;
exception
:sub_object := :part3;
where o.owner = :part1
and o.object_name = :part2
and rownum = 1;
check_mview;
return;
exception
if :part2 is null and :part3 is null
then
select 'USER', null, :part1
from sys.all_users u
where u.username = :part1
and rownum = 1;
return;
end if;
exception
if :part2 is null and :part3 is null and :deep != 0
then
select 'ROLE', null, :part1
from sys.session_roles r
where r.role = :part1
and rownum = 1;
return;
end if;
exception
:object_owner := null;
:object_type := null;
:object_name := null;
:PART1 = PMOUSER
:OBJECT_TYPE = Null
:OBJECT_OWNER = Null
:OBJECT_NAME = Null
:PART2 = PKG_PIPELINE_NEW_UI
:SUB_OBJECT = Null
:PART3 = SP_PIPELINE_MAIN
:DEEP = 0
:CUR_SCHEMA = PMOUSER
4/18/2013 8:55:39 PM TOracleQuery PLSQLDevForm.ResolveSymbolQuery End
Duration = 0.062
and po.object_type = 'PROCEDURE'
:OBJECT_TYPE = PROCEDURE
4/18/2013 8:55:39 PM TOracleQuery $0418AD60 End (0 records processed)
Duration = 0.156
4/18/2013 8:55:39 PM AddPlugInPopups Start 0
4/18/2013 8:55:39 PM AddPlugInPopups End
4/18/2013 8:55:40 PM TOracleQuery $0418AD60 Start Query.Execute
:SUB_OBJECT = Null
4/18/2013 8:55:40 PM TOracleQuery $0418AD60 End (1 record processed)
Duration = 0
:SUB_OBJECT = Null
Duration = 0
4/18/2013 8:55:40 PM Create TTestForm Start
4/18/2013 8:55:40 PM Create TTestForm Inherited
4/18/2013 8:55:40 PM NavigationBookmarks.EnableButtons(Rebuild)
4/18/2013 8:55:40 PM NavigationBookmarks: Backward=1, Forward=0
4/18/2013 8:55:40 PM AddNavigationBookmark starts
4/18/2013 8:55:40 PM AddNavigationBookmark GNV00002
4/18/2013 8:55:40 PM NavigationBookmarks: Backward=2, Forward=0
4/18/2013 8:55:40 PM AddNavigationBookmark ends
4/18/2013 8:55:40 PM Create TTestForm SetupMainFont
4/18/2013 8:55:40 PM Create TTestForm Activate
4/18/2013 8:55:40 PM Create TTestForm Activate done
4/18/2013 8:55:40 PM Create TTestForm UpdateWindowList
4/18/2013 8:55:40 PM Create TTestForm Positioning
4/18/2013 8:55:40 PM Create TTestForm Finished
4/18/2013 8:55:52 PM SetConnected starts
4/18/2013 8:55:52 PM SetConnected: ForceLogoff starts
4/18/2013 8:55:52 PM SetConnected: ForceLogoff ends
4/18/2013 8:55:52 PM SetConnected: Connect starts
4/18/2013 8:55:52 PM TOracleSession $04A83500 Start Session.LogOn as PMOUSER@RPNET02
4/18/2013 8:55:52 PM TOracleQuery Query Start Query.Execute
4/18/2013 8:55:52 PM TOracleQuery Query End (1 record processed)
Duration = 0
4/18/2013 8:55:52 PM TOracleSession $04A83500 End
Duration = 0.031
4/18/2013 8:55:52 PM SetConnected: (Dis)connect ends
4/18/2013 8:55:52 PM SetSessionAction starts: Test Window - Script for procedure PKG_PIPELINE_NEW_UI.SP_PIPELINE_MAIN@RPNET02
4/18/2013 8:55:52 PM TOracleQuery $04AB6450 Start Query.Execute
4/18/2013 8:55:52 PM TOracleQuery $04AB6450 End (1 record processed)
Duration = 0
4/18/2013 8:55:52 PM TOracleQuery BytesPerCharacterQuery Start Query.Execute
4/18/2013 8:55:52 PM TOracleQuery BytesPerCharacterQuery End (1 record processed)
Duration = 0
Duration = 0
:ACTION = Test Window - Script for procedure PKG_PIPELINE_NEW_UI.SP_PIPELINE_MAIN@RPNET02
Duration = 0
4/18/2013 8:55:52 PM SetSessionAction ends
4/18/2013 8:55:52 PM ExecuteConnectScript starts
4/18/2013 8:55:52 PM ExecuteConnectScript ends
Duration = 0.016
4/18/2013 8:55:52 PM InitHTPOutput starts
SQL = begin if owa.num_cgi_vars is null then owa.num_cgi_vars := 0; end if; end;
Duration = 0
4/18/2013 8:55:52 PM InitHTPOutput finished
4/18/2013 8:55:52 PM EnableOutput starts
4/18/2013 8:55:52 PM TOracleQuery PLSQLDevForm.EnableOutputQuery Start Query.Execute
SQL = begin
if :enable = 0 then
sys.dbms_output.disable;
else
sys.dbms_output.enable(:size);
end if;
:ENABLE = 1
:SIZE = 10000
4/18/2013 8:55:52 PM TOracleQuery PLSQLDevForm.EnableOutputQuery End
Duration = 0
4/18/2013 8:55:52 PM EnableOutput done
4/18/2013 8:55:52 PM InitializeTargetSession starts
4/18/2013 8:55:52 PM TOracleQuery Debugger.InitializeTargetQuery Start Query.Execute
SQL = begin
--sys.dbms_session.reset_package;
sys.dbms_debug.probe_version(major => :major, minor => :minor);
:debug_session_id := sys.dbms_debug.initialize;
sys.dbms_debug.debug_on;
:DEBUG_SESSION_ID = Null
:MAJOR = Null
:MINOR = Null
4/18/2013 8:55:52 PM TOracleQuery Debugger.InitializeTargetQuery End
Duration = 0.093
4/18/2013 8:55:52 PM TOracleSession Debugger.Session Start Session.LogOn as PMOUSER@RPNET02
Duration = 0
Duration = 0
Duration = 0
4/18/2013 8:55:52 PM TOracleSession Debugger.Session End
Duration = 0.047
4/18/2013 8:55:52 PM SetSessionAction starts: Debug Test Window - Script for procedure PKG_PIPELINE_NEW_UI.SP_PIPELINE_MAIN@RPNET02
4/18/2013 8:55:52 PM TOracleQuery $04AB5D70 Start Query.Execute
4/18/2013 8:55:52 PM TOracleQuery $04AB5D70 End (1 record processed)
Duration = 0.016
:ACTION = Debug Test Window - Script for procedure PKG_PIPELINE_NEW_UI.SP_PIPELINE_MAIN@RPNET02
Duration = 0
4/18/2013 8:55:52 PM InitializeTargetSession ends
4/18/2013 8:55:52 PM InitStatistics starts
4/18/2013 8:55:52 PM TStatistics.Init starts
4/18/2013 8:55:52 PM TStatistics.Init ends
4/18/2013 8:55:53 PM InitStatistics ends
4/18/2013 8:55:53 PM TOracleQuery $04AB5D70 Start Query.Execute
SQL = alter session set plsql_debug=true
4/18/2013 8:55:53 PM TOracleQuery $04AB5D70 End
Duration = 0
4/18/2013 8:55:53 PM NavigationBookmarks.EnableButtons(Rebuild)
4/18/2013 8:55:53 PM NavigationBookmarks: Backward=2, Forward=0
4/18/2013 8:55:53 PM Debugger.Attach starts
4/18/2013 8:55:53 PM TSQL
Hi Marco,
i sent you several files, where breaking a debug session, causes to hang up PSD. Did this help in any way, or are there other ways we can help you to identify and fix this bug?
Regards Benjamin
Benjamin,
do you run the debug on a cluster?
If so: this generated errors and hanging PLSQL instances. Connect to a specific instance when debugging.
i also have such problem!! i don't have clusters, simple 1 instance without links to remote db. very annoying, because restart the application didn't going successfull (old versions of edited files, old state of db objects)
Version 10.0.3.1701
I have this issue also and have posted on this site before about it. I have also seen many other posts regarding the same issue.
https://forums.allroundautomations.com/ubb//ubbthreads.php?ubb=showflat&Number=47034#Post47034
For me, it always occurs if, during debug, I hove the mouse over a line of code that is referencing a multi-level array. the above link gives a working example. It seems the guys at allround are not really interested in this as I've not seen one useful response to what is quite obviously a major bug.
Since most of our code base employs these structures it renders the pl/sql developer debugger pretty much useless as far as I am concerned. I think we will be moving back to Toad before long. It may be more expensive but at the very least you get responses from their support staff.
Any news on this bug? Any additional things we can do to help identifying the problem?
By now, you can't break any debug session, without killing PSD, and losing all unsaved programming results.
Very annoying and frustrating :(
