B BWendling Member³ Aug 11, 2004 #1 Is there a way to use replacement variables in the Test window? It works fine in the SQL window.
ScottMattes Member³ Aug 11, 2004 #1 You use bind variables var_name) in the test window. After typing them in go to the lower right area, under the test area edit portion, and right click and select scan variables.
