Can you verify these steps for your PVCS installation? Please make sure that the installed PVCS SCC Interface matches the version of you PVCS Version Manager software.
After installing the Source control plugin for the PL/SQL Developer Application, the applications fails to start up (There are no errors reported). In order to startup my PL/SQL Developer Application I have to delete the file named VCS.dll within the PlugIns folder
Having read the previous posting I have checked my registry settings, see below:
Under
'HKEY_LOCAL_MACHINE\Software\SourceCodeControlProvider\InstalledSCCProviders'
there is a key 'PVCS Source Control' with a value 'SOFTWARE\PVCS\Interfaces\SCC'
Under
'HKEY_LOCAL_MACHINE\SOFTWARE\SourceCodeControlProvider' there is an key 'ProviderRegKey' with a value 'SOFTWARE\PVCS\Interfaces\SCC'
Under
'HKEY_LOCAL_MACHINE\SOFTWARE\PVCS\Interfaces\SCC' there is an key 'SCCServerPath' with a value 'D:\Program Files\PVCS\VM\WIN32\BIN\PVCS_IFC.DLL' (this dll does exist)
Are there any other registry setting that I should check?
Josie
Originally posted by mkalter: Can you verify these steps for your PVCS installation? Please make sure that the installed PVCS SCC Interface matches the version of you PVCS Version Manager software.
There must be something terribly wrong with the SCC Interface of your PVCS installation then. Can you reinstall PVCS and its integration to make sure that everything is configured properly?
