koja
Strictly this is not a Beta issue. I use projects all the time. The issue is that when I open a project while the current main connection is different than the connection I used when creating the project all windows opened with the project get pinned(I don't set connection settings for the projects). Can this be fixed. A workaround would be to have the possibility to unpin all open windows. We have multiple environments with the same schema's and objects, so setting a fixed connection with the project is not beneficial for the way I work.
