Problems with Oracle Client (PL/SLQ Developer)
Fika
Hi Guys. I have just downloaded the free trial and I am battling to recover my files... When I try to log on it say
Initialization error
Oracle Client not properly installed
OracleHomeKey:
OracleHomeDir:
Can anybody please help because I need these file as in yesterday?
You will need to install the 32 Bit Oracle Client Software. This is a requirement for PL/SQL Developer.
Recover what files?
If you stored some documents in an Oracle DB, then you can simply use any other tool (e.g. Oracle SQL Developer) to access the DB and extract those, if PLD is not working.
If you are talking about DB scripts you made using PLD, then you have them on your drives and as they are simple text files, you can open them using any text editing application, like MS Notepad.
