Dear all,
I got a error message that '(Not logged on)-PL/SQL Developer' when I login to DB.
detail of meaasge is
Initialization error
Could not initialize "C:\orant\bin\oci.dll"
Make sure you have the 64bits Oracle Client installed.
OracleHomeKey:
OracleHomeDir: C\orant
Found: oci.dll
Found ORA803.DLL
Found ora805.dll
Using: C\orant\bin\oci.dll
LoadLibrary(C:\orant\bin\oci.dll) returned 0
I've update TNSnames file also,
please let me know how to logon to DB.
and here is my Info.
PL/SQL Developer
Version 12.0.5.1828 (64 bit)
31.111159 - 10 user license
Service Contract: 2018-01-01
Windows 7 Build 7601 (Service Pack 1)
Physical memory : 16,695,972 kB (13,111,892 available)
Paging file : 33,390,084 kB (29,633,996 available)
Virtual memory : 8,589,934,464 kB (8,589,630,296 available)
Parameters
C:\Program Files\PLSQL Developer 12\plsqldev.exe
Preferences
Session mode: Multi
OCI Library:
Use OCI7: False
Preference Files
C:\Program Files\PLSQL Developer 12\Preferences\Default\Default.ini
C:\Users\Juyoung\AppData\Roaming\PLSQL Developer 12\Preferences\Juyoung\default.ini
License File
C:\ProgramData\PLSQL Developer\aalf.dat
Debug file
C:\Users\Juyoung\AppData\Roaming\PLSQL Developer 12\PlSqlDev.elf
Plug-Ins
*Active Query Builder (C:\Program Files\PLSQL Developer 12\PlugIns\ActiveQueryBuilder.dll)
*PL/SQL Documentation (plsqldoc) (C:\Program Files\PLSQL Developer 12\PlugIns\plsqldoc.dll)
*Red Gate Deployment Plug-In 1.3.0 (C:\Program Files\PLSQL Developer 12\PlugIns\RedGate.dll)
(* is Active)
Aliases
Homes
DLLs
C:\orant\bin\ORA803.DLL
C:\orant\bin\ORA804.DLL
C:\orant\bin\ora805.dll
TNS File
Using
Home:
DLL:
OCI: not initialized
Process
Working Set = 127,819,776
Memory = 46,144,216
GDI Objects = 798
User Objects = 402
Handles = 166
Monitors
PixelsPerInch = 96
Id = 0
Primary = True
Handle = 65537
Left = 0
Top = 0
Width = 1920
Height = 1080
Id = 1
Primary = False
Handle = 65539
Left = 1920
Top = 0
Width = 1920
Height = 1080
MainFormOnTaskbar = False
OracleHomeKey:
Found: oci.dll
Found ORA803.DLL
Found ora805.dll
PL/SQL Developer
Parameters
Preferences
Session mode: Multi
OCI Library:
Use OCI7: False
Preference Files
License File
Debug file
Plug-Ins
(* is Active)
Aliases
Homes
DLLs
TNS File
Using
Home:
DLL:
Process
Memory = 46,144,216
GDI Objects = 798
User Objects = 402
Handles = 166
Monitors
PixelsPerInch = 96
Id = 0
Primary = True
Handle = 65537
Left = 0
Top = 0
Width = 1920
Height = 1080
Id = 1
Primary = False
Handle = 65539
Left = 1920
Top = 0
Width = 1920
Height = 1080
