Problem with VCS...
agambini
Hello there,
we are evaluating PLSQL Developer and it's very important to use a VCS for us.
I can check in and check out the files if I'm viewing a file from my work area. But when I'm just opening a project and I try to check it out the Check Out Files window is empty.
On the contrary, if first, I try to check out a file from the work area, then I can see the file (and only this) in the Check Out Files window. Why?
Thanks in advance,
Andrea Gambini
We are using "QVCS Version 3.5 Quma Software" with a share project. Have you any advice about it?
We are almost sure to buy Allround PLSQLDEVELOPER but we are not so sure to buy this VCS...
Andrea Gambini
