problem with display numeric values
PeTe
I have problem with display numeric values in SQL Window, Test Window and Report Window.
I have table test with column:
max number(20,12)
nd execute:
insert into test values (1433.143049998981)
When I try:
declare
  x number;
  select max into x from test;
  dbms_output.put_line(x);
everything look good.
But
select max from test;
in SQL Window, Test Window and Report Window give me:
max
1433,143049998980
Suggestion: maby PLSQL Developer include comma into precision???
This problem is caused by floating point precision. If you enable the SQL Window preference "Number fields to_char" (Tools > Preferences > SQL Window tab page), these high-precision numbers will be converted to strings on the server, using the Oracle NLS settings, and without losing precision.
