Lukasz Indeka
I have a package with the following specification:
When I try to write the following anonymous block:
and activate code assistant by the keyboard shortcut (code assistant automatic activation is disabled in my configuration), then PL/SQL Developer always shows the list of parameters of the first overload. It happens after each comma, even if I selected for the previous line the second overload of the procedure. I'm not sure if it's caused by disabling the automatic activation of the code assistant, but I have the filling, that it used to worked right in the PL/SQL Developer 15.
SQL:
create or replace package test_schema.test_package
authid current_user
is
procedure send_all
(p_update in boolean
,p_send in boolean
,p_data in boolean default true
,p_statuses in boolean default true
procedure send_all
(p_update in boolean default true
,p_send in boolean default true
,p_process_wod in boolean default true
,p_process_wod_bank in boolean default true
,p_process_uod in boolean default true
,p_process_wop in boolean default true
,p_process_fk in boolean default true
,p_process_wod_sts in boolean default true
,p_process_uod_sts in boolean default true
,p_process_wop_sts in boolean default true
end test_package;
SQL:
test_schema.test_package.send_all(p_update => true
,p_process_wod => false
