PLSQL Developer 12 hangs and not responding while loading plugins
PL/SQL Developer
Version 12.0.3.1821 (32 bit)
Windows 10 (64-bit) Build 14393
Physical memory : 8,260,700 kB (4,411,320 available)
Paging file : 10,226,780 kB (5,511,216 available)
Virtual memory : 2,097,024 kB (1,852,604 available)
Parameters
C:\Program Files (x86)\PLSQL Developer 12\plsqldev.exe
DebugSQL
Preferences
Session mode: Multi
OCI Library:
Use OCI7: False
Preference Files
Debug file
C:\Users\Bilal.Sarioz\AppData\Roaming\PLSQL Developer 12\PlSqlDev.elf
Plug-Ins
Process
Working Set = 80,314,368
Memory = 32,349,924
GDI Objects = 350
User Objects = 215
Handles = 262
Monitor
PixelsPerInch = 96
Id = 0
Primary = True
Handle = 65537
Left = 0
Top = 0
Width = 1600
Height = 900
MainFormOnTaskbar = False
22-Jun-17 10:56:09 AM Application started
00:00:00.010 InitPreferences
00:00:00.011 Load C:\Users\Bilal.Sarioz\AppData\Roaming\PLSQL Developer 12\Preferences\default = 0
00:00:00.012 PreferenceSet.Load C:\Users\Bilal.Sarioz\AppData\Roaming\PLSQL Developer 12\Preferences\default\Default.ini
00:00:00.014 PreferenceSet.Load OK
00:00:00.015 Determine LocalPrefPath
00:00:00.016 [1]: C:\Users\Bilal.Sarioz\AppData\Roaming\PLSQL Developer 12\Preferences
00:00:00.017 LocalPrefPath: C:\Users\Bilal.Sarioz\AppData\Roaming\PLSQL Developer 12\Preferences\Bilal.Sarioz
00:00:00.018 Load C:\Users\Bilal.Sarioz\AppData\Roaming\PLSQL Developer 12\Preferences\Bilal.Sarioz = 0
00:00:00.019 PreferenceSet.Load C:\Users\Bilal.Sarioz\AppData\Roaming\PLSQL Developer 12\Preferences\Bilal.Sarioz\default.ini
00:00:00.020 PreferenceSet.Load OK
00:00:00.022 PreferenceSet.Load C:\Users\Bilal.Sarioz\AppData\Roaming\PLSQL Developer 12\Preferences\Bilal.Sarioz\user.prefs
00:00:00.024 PreferenceSet.Load OK
00:00:00.024 InitPreferences end
00:00:00.025 SortPreferenceSets
00:00:00.026 - Default Bilal.Sarioz
00:00:00.027 - System Default
00:00:00.296 UpdateConnections
00:00:00.299 UpdateConnectionsChildList start
00:00:00.300 UpdateConnectionsChildList ConnectionFolders.Count = 1
00:00:00.301 UpdateConnectionsChildList CheckList.Count = 1
00:00:00.302 UpdateConnectionsChildList RemoveList.Count = 0
00:00:00.303 UpdateConnectionsChildList EndUpdate
00:00:00.303 UpdateConnectionsChildList end
00:00:00.308 DoUpdateChildList starts
00:00:00.363 Lock
00:00:00.364 UnLock
00:00:00.405 pfReadRegistry(PL/SQL Developer 12\Shell\Open\Command, )
00:00:00.406 ReadString Faled
00:00:00.406 pfReadRegistry:
00:00:00.407 CalculateToolbarGlyphs (DPI = 96)
00:00:00.408 CalculateToolbarGlyphs done
00:00:00.973 Splash: Starting PL/SQL Developer 12
00:00:00.976 Splash: Version 12.0.3.1821 (32 bit)
00:00:00.979 LoadPreferences
00:00:00.980 LoadPreferences searching for default
00:00:00.981 C:\Users\Bilal.Sarioz\AppData\Roaming\PLSQL Developer 12\Preferences\Bilal.Sarioz\default.ini
00:00:00.982 LoadPreferences NewPref := nil
00:00:00.983 LoadPreferences Reading preferences
00:00:00.986 Splash: Reading preferences
00:00:01.004 FormResize
00:00:01.041 FormResize
00:00:01.047 LoadPreferences ReadPosition
00:00:01.068 FormResize
00:00:01.105 FormResize
00:00:01.107 LoadPreferences ToolsBrowserItemClick(nil)
00:00:01.114 LoadPreferences CreateBrowserFilters...
00:00:01.115 LoadPreferences Files
00:00:01.117 LoadPreferences Printer
00:00:01.118 LoadPreferences FileBrowserFolders
00:00:01.119 LoadPreferences Connections
00:00:01.120 LoadPreferences BrowserFolders
00:00:01.121 LoadPreferences
00:00:01.122 LoadPreferences end
00:00:01.401 MacroLibFilename: C:\OracleERP\Work Logs\Bilal.Sarioz.emlib
00:00:01.457 Splash: Reading keywords
00:00:01.459 GetRootFile: C:\Users\Bilal.Sarioz\AppData\Roaming\PLSQL Developer 12\default.kwf
00:00:01.466 Logging on..
00:00:01.468 Creating new session
00:00:01.468 Initializing new session
00:00:01.469 Setting new session parameters
00:00:01.471 Setting logon session
00:00:01.472 OCI Initialization starts
00:00:01.480 OCI Initialization done
00:00:01.480 OracleHomeKey: SOFTWARE\ORACLE\KEY_OraClient11g_home1
OracleHomeDir: C:\app\Bilal.Sarioz\product\11.2.0\client_1
Found: oci.dll
Using: C:\app\Bilal.Sarioz\product\11.2.0\client_1\oci.dll
00:00:01.481 Logon2 starting
00:00:01.482 Logon2.Execute starts
00:00:05.758 TOracleSession $07EE48B0 Start Session.LogOn as apps@erpuNT
00:00:06.088 TOracleQuery Query Start Query.Execute
00:00:06.102 TOracleQuery Query End (1 record processed)
Duration = 0.016
00:00:06.104 TOracleSession $07EE48B0 End
Duration = 0.344
00:00:06.130 Logon2.Execute done
00:00:06.131 Logon2 done
00:00:06.134 TOracleQuery $080D19E0 Start Query.Execute
00:00:06.142 TOracleQuery $080D19E0 End (1 record processed)
Duration = 0.016
00:00:06.143 TOracleSession $07EE6570 Start Session.LogOn as apps@erpuNT
00:00:06.261 TOracleQuery Query Start Query.Execute
00:00:06.267 TOracleQuery Query End (1 record processed)
Duration = 0
00:00:06.268 TOracleSession $07EE6570 End
Duration = 0.109
00:00:06.274 TOracleQuery BytesPerCharacterQuery Start Query.Execute
00:00:06.275 TOracleQuery BytesPerCharacterQuery Start Query.Execute
00:00:06.279 TOracleQuery BytesPerCharacterQuery End (1 record processed)
Duration = 0
00:00:06.280 TOracleQuery BytesPerCharacterQuery Start Query.Execute
00:00:06.282 TOracleQuery BytesPerCharacterQuery End (1 record processed)
Duration = 0
00:00:06.283 TOracleQuery BytesPerCharacterQuery Start Query.Execute
00:00:06.286 TOracleQuery BytesPerCharacterQuery End (1 record processed)
Duration = 0.016
00:00:06.287 TOracleQuery $080D1CA0 Start Query.Execute
SQL = begin :n := user; end;
:N = Null
00:00:06.289 TOracleQuery BytesPerCharacterQuery End (1 record processed)
Duration = 0.016
00:00:06.290 TOracleQuery $080D1720 Start Query.Execute
SQL = /*
The name + type results of these queries will be used by the Code Assistant
if the "Describe Context" option is enabled. After typing 3 or more characters
the Code Assistant will show a list of matching names.
Separate multiple queries with semi-colons and use the :schema bind variable
to restrict names to the currently connected user.
In case of an error the query results will be omitted. No error message will
be displayed.
Place this file in the PL/SQL Developer installation directory for all users,
or in the "%APPDATA%\PLSQL Developer" directory for a specific user.
select object_name, object_type
from sys.all_objects o
where o.owner = :schema
:SCHEMA = APPS
00:00:06.291 TOracleQuery $080D1CA0 End
Duration = 0
00:00:06.292 TOracleQuery Query Start Query.Execute
SQL = select * from v$version
00:00:06.299 TOracleQuery Query End (5 records processed)
Duration = 0
00:00:06.300 LogonHistorySave start
00:00:06.301 ChangeUserPref LogonHistory,
00:00:06.302 ChangeUserPref DSA,
00:00:06.303 ChangeUserPref end
00:00:06.304 ChangeUserPref ColumnAssociations,
00:00:06.305 ChangeUserPref end
00:00:06.306 ChangeUserPref ImportAssociations,
00:00:06.307 ChangeUserPref end
00:00:06.308 ChangeUserPref BrowserFilters,
00:00:06.309 ChangeUserPref end
00:00:06.309 ChangeUserPref FileBrowserFolders,
00:00:06.310 ChangeUserPref end
00:00:06.311 ChangeUserPref Connections,
00:00:06.313 ChangeUserPref end
00:00:06.313 ChangeUserPref BrowserFolders,
00:00:06.315 ChangeUserPref end
00:00:06.315 ChangeUserPref SessionQueries,
00:00:06.317 ChangeUserPref end
00:00:06.318 ChangeUserPref ExternalTools,
00:00:06.318 ChangeUserPref end
00:00:06.319 ChangeUserPref Documents,
00:00:06.320 ChangeUserPref end
00:00:06.321 ChangeUserPref WebSearches,
00:00:06.322 ChangeUserPref end
00:00:06.323 ChangeUserPref Reports,
00:00:06.324 ChangeUserPref end
00:00:06.325 ChangeUserPref CurrentConnections,
00:00:06.325 ChangeUserPref end
00:00:06.326 PreferenceSet.Save
00:00:06.327 PreferenceSet Filename = C:\Users\Bilal.Sarioz\AppData\Roaming\PLSQL Developer 12\Preferences\Bilal.Sarioz\user.prefs
00:00:06.328 PreferenceSet AltFile = user.prefs
00:00:06.329 PreferenceSet.Save end
00:00:06.330 LogonHistorySave end
00:00:06.332 Splash: connected
00:00:06.333 FormCreate Logon.Executed -1
00:00:06.339 FormCreate SessionChanged
00:00:06.343 TOracleQuery Query Start Query.Execute
00:00:06.348 TOracleQuery Query End (5 records processed)
Duration = 0.016
00:00:06.349 TOracleQuery $080D1F60 Start Query.Execute
00:00:06.385 TOracleQuery $080D1F60 End (1 record processed)
Duration = 0.031
00:00:06.386 SessionChanged SetDBAViews
00:00:06.387 TOracleQuery $080D1F60 Start Query.Execute
00:00:06.392 TOracleQuery $080D1F60 End (0 records processed)
Duration = 0
00:00:06.393 TOracleQuery $080D1F60 Start Query.Execute
00:00:06.398 TOracleQuery $080D1F60 End (0 records processed)
Duration = 0.016
00:00:06.410 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.125
00:00:06.411 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:06.414 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:06.416 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:06.420 SessionChanged Authorizations.Load
00:00:06.421 SessionChanged EnableAuthorizedMenus
00:00:06.422 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:06.423 WindowAllowed(1)
00:00:06.423 WindowAllowed done
00:00:06.424 WindowAllowed(1)
00:00:06.425 WindowAllowed done
00:00:06.426 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:06.427 ExecuteConnectScript starts
00:00:06.428 GetRootFile: C:\Users\Bilal.Sarioz\AppData\Roaming\PLSQL Developer 12\AfterConnect.sql
00:00:06.429 TOracleQuery $080D1F60 Start Query.Execute
00:00:06.435 TOracleQuery $080D1F60 End (1 record processed)
Duration = 0
00:00:06.437 ExecuteConnectScript ends
00:00:06.440 SetSessionAction starts: Primary Session
00:00:06.441 TOracleQuery $080D1F60 Start Query.Execute
SQL = select null from dual
00:00:06.446 TOracleQuery $080D1F60 End (1 record processed)
Duration = 0
00:00:06.447 TOracleQuery $080D1F60 Start Query.Execute
:ACTION = Primary Session
00:00:06.450 TOracleQuery $080D1F60 End
Duration = 0
00:00:06.451 SetSessionAction ends
00:00:06.480 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.047
00:00:06.481 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:06.545 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.063
00:00:06.547 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:06.554 SessionChanged LoadRecentObjects
00:00:06.556 SessionChanged Logoff secondary sessions
00:00:06.557 TOracleQuery PLSQLDevForm.DynamicQuery Start Query.Execute
SQL = select value from v$nls_parameters where parameter = 'NLS_DATE_FORMAT'
00:00:06.563 TOracleQuery PLSQLDevForm.DynamicQuery End (1 record processed)
Duration = 0
00:00:06.564 SessionChanged
Found: oci.dll
00:00:06.565 SessionChanged Notify children
00:00:06.565 SessionChanged EnableChildFunctions
00:00:06.575 Lock
00:00:06.576 UnLock
00:00:06.578 UpdateChildList starts
00:00:06.822 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.281
00:00:06.823 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:06.828 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:06.829 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:06.832 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.015
00:00:06.834 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:06.838 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:06.839 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:06.843 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:06.844 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:06.847 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.016
00:00:06.849 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:06.854 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:06.855 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:06.858 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:06.860 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:06.863 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.016
00:00:06.865 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:06.868 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:06.870 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:06.875 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:06.876 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:06.879 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.015
00:00:06.880 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:06.884 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:06.886 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:06.890 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:06.892 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:06.895 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.016
00:00:06.896 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:06.900 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:06.901 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:06.904 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:06.906 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:06.911 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.016
00:00:06.912 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:06.915 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:06.917 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:06.920 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:06.921 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:06.925 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:06.926 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:06.930 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:06.931 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:06.935 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:06.936 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:06.939 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:06.941 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:06.944 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:06.946 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:06.950 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:06.951 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:06.955 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:06.957 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:06.961 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:06.962 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:06.965 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:06.967 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:06.970 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:06.971 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:06.975 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:06.976 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:06.980 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:06.981 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:06.986 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:06.988 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:06.992 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:06.993 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:06.996 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:06.998 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:07.001 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:07.003 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:07.006 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:07.008 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:07.011 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:07.035 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:07.038 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:07.040 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:07.044 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:07.045 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:07.578 Splash: .
00:00:07.915 ReadTemplateFiles C:\OracleERP\Work Logs
00:00:08.185 TOracleQuery $080D1720 End (100 records processed)
Duration = 1.14
00:00:08.186 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.191 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.192 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.196 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.198 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.205 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.206 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.232 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.016
00:00:08.233 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.238 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.016
00:00:08.239 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.253 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.254 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.258 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.259 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.262 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.264 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.267 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.268 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.271 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.273 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.276 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.278 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.280 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.282 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.285 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.016
00:00:08.287 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.290 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.291 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.294 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.295 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.299 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.300 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.304 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.305 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.309 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.310 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.313 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.315 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.337 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.031
00:00:08.338 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.341 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.343 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.346 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.348 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.351 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.352 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.356 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.357 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.362 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.363 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.366 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.368 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.375 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.376 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.379 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.015
00:00:08.381 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.385 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.387 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.390 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.391 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.395 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.016
00:00:08.396 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.399 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.401 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.404 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.405 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.410 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.411 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.416 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.417 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.421 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.422 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.426 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.015
00:00:08.427 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.431 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.432 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.436 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.438 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.441 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.016
00:00:08.443 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.447 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.448 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.454 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.456 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.459 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.015
00:00:08.460 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.464 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.465 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.468 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.470 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.474 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.016
00:00:08.475 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.479 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.481 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.486 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.488 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.504 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.015
00:00:08.506 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.509 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.511 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.514 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.516 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.520 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.016
00:00:08.521 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.526 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.527 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.535 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.536 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.540 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.542 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.559 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.015
00:00:08.561 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.565 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.568 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.571 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.573 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.577 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.580 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.583 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.015
00:00:08.585 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.588 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.590 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.604 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.016
00:00:08.606 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.609 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.611 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.615 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.016
00:00:08.617 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.620 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.622 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.625 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.645 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.650 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.652 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.656 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.658 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.662 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.016
00:00:08.664 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.667 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.670 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.673 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.675 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.679 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.681 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.712 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.031
00:00:08.714 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.718 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.721 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.724 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.016
00:00:08.726 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.730 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.732 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:08.736 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:08.738 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.185 TOracleQuery $080D1720 End (100 records processed)
Duration = 1.437
00:00:10.187 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.192 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.016
00:00:10.194 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.199 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.201 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.205 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.207 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.211 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.212 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.216 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.217 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.221 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.223 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.226 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.228 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.233 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.235 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.240 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.016
00:00:10.242 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.246 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.247 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.251 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.253 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.256 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.258 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.261 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.262 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.266 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.268 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.272 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.016
00:00:10.274 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.277 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.278 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.282 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.284 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.287 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.016
00:00:10.289 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.293 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.294 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.298 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.299 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.330 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.332 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.335 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.336 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.339 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.341 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.344 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.346 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.349 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.016
00:00:10.351 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.354 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.356 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.358 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.360 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.440 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.078
00:00:10.442 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.446 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.448 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.452 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.454 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.457 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.015
00:00:10.459 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.463 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.464 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.468 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.469 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.482 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.016
00:00:10.484 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.487 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.489 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.492 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.494 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.497 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.499 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.502 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.504 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.508 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.509 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.513 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.514 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.518 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.520 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.524 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.526 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.529 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.530 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.533 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.535 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.538 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.540 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.543 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.545 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.550 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.551 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.555 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.556 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.559 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.561 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.749 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.188
00:00:10.751 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.764 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.015
00:00:10.766 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.770 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.016
00:00:10.773 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.776 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.778 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.782 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.784 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.788 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.791 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.795 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.798 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.813 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.015
00:00:10.815 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.818 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.016
00:00:10.821 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.825 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.827 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.832 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.834 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.849 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.016
00:00:10.851 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.854 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.856 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.860 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.862 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.866 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.868 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.871 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.873 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.877 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.879 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.882 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.884 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.895 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.016
00:00:10.897 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.900 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.902 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.906 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.908 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.912 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.016
00:00:10.914 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.917 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.920 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.923 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.925 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.935 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.937 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.941 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.942 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.945 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.947 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.952 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.953 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.956 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.958 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.961 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.963 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.967 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.970 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.975 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.016
00:00:10.978 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.981 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.984 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.987 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.990 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.993 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:10.995 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:10.999 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.001 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.004 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.015
00:00:11.007 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.020 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.016
00:00:11.023 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.026 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.028 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.031 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.053 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.056 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.058 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.061 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.063 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.066 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.068 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.077 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.079 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.083 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.015
00:00:11.098 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.132 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.031
00:00:11.133 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.202 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.063
00:00:11.206 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.210 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.214 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.227 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.016
00:00:11.230 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.234 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.236 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.241 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.016
00:00:11.243 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.246 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.248 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.253 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.255 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.259 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.261 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.266 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.268 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.272 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.274 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.280 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.281 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.286 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.016
00:00:11.288 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.298 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.300 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.303 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.306 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.309 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.312 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.317 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.320 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.323 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.325 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.329 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.332 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.336 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.015
00:00:11.338 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.342 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.344 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.347 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.349 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.352 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.354 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.358 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.359 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.402 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.047
00:00:11.404 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.426 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.016
00:00:11.428 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.431 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.433 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.438 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.440 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.467 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.031
00:00:11.470 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.473 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.476 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.497 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.016
00:00:11.500 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.504 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.506 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.511 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.514 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.524 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.016
00:00:11.526 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.529 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.532 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.536 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.539 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.545 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.547 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.565 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.015
00:00:11.567 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.571 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.572 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.596 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.015
00:00:11.598 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.634 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.047
00:00:11.636 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.760 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.125
00:00:11.763 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.767 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.770 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.776 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.016
00:00:11.779 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.782 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.785 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.789 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.016
00:00:11.792 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.796 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.798 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.802 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.805 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.809 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.811 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.814 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.817 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.821 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.016
00:00:11.823 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.827 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.829 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.833 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.835 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.839 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.841 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.845 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.847 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.852 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.016
00:00:11.855 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.858 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.860 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.883 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.885 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.889 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.891 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.895 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.897 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.901 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.902 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.906 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.908 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.912 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.016
00:00:11.914 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.917 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.919 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.922 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.924 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.928 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.015
00:00:11.929 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.934 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.936 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.939 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.942 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.946 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.948 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.952 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.955 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.965 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.015
00:00:11.967 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.971 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.973 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:11.976 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:11.979 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:12.029 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.047
00:00:12.031 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:12.079 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.047
00:00:12.083 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:12.086 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:12.089 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:12.093 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:12.096 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:12.100 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.016
00:00:12.102 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:12.106 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:12.108 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:12.111 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:12.113 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:12.131 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.031
00:00:12.133 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:12.136 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:12.139 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:12.143 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:12.146 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:12.150 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:12.154 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:12.157 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:12.160 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:12.163 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.016
00:00:12.166 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:12.170 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:12.172 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:12.188 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.015
00:00:12.191 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:12.353 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.172
00:00:12.356 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:12.360 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:12.364 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:12.367 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:12.371 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:12.375 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:12.379 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:12.382 TOracleQuery $080D1720 End (100 records processed)
Duration = 0.015
00:00:12.385 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:12.388 TOracleQuery $080D1720 End (100 records processed)
Duration = 0
00:00:12.392 TOracleQuery $080D1720 Start Query.Next for up to 100 records
00:00:12.395 TOracleQuery $080D
And the issue seems here
00:00:34.750 TOracleQuery $080D1720 Start Query.Execute
SQL =
select db_link as object_name, 'DATABASE LINK' as object_type
from sys.all_db_links o
or o.owner = 'PUBLIC'
:SCHEMA = APPS
00:00:34.773 TOracleQuery $080D1720 End (8 records processed)
Duration = 0.016
00:00:34.775 TOracleSession $07EE6570 Start Session.LogOff
00:00:34.896 TOracleSession $07EE6570 End
Duration = 0.125
00:09:31.117 ReadTemplateFiles Done
00:09:35.439 SortPreferenceSets
00:09:35.440 - Default Bilal.Sarioz
00:09:35.440 - System Default
00:09:35.555 TOracleQuery $06EEEAD0 Start Query.Execute
00:09:35.560 TOracleQuery $06EEEAD0 End (0 records processed)
Duration = 0
00:09:35.561 TOracleQuery $06EEEAD0 Start Query.Execute
00:09:35.567 TOracleQuery $06EEEAD0 End (0 records processed)
Duration = 0
It waited 9 minutes from one step to another
Did it work before? If so, can you reset all your preferences and settings by renaming
To (for example):
C:\Users\Bilal.Sarioz\AppData\Roaming\PLSQL Developer 12\Preferences\Bilal.Sarioz.Disabled
You can rename it back after this test to restore your preferences.
Thanks Marco,
When I did this, it opens faster although not connecting to database.
Which preference you think that is causing this?
Regards
Bilal
I have similar problem.
If I connect to computer with PL/SQL developer using remote desktop, my plugins does not load. I must use "noplugins" command line option.
Using computer locally evrything works OK.
