PL/SQL is there a way to set queries to run automatically?
Hello!
In PL/SQL is there a way to set queries to run automatically? For ex: I have query X that needs to run everyday at 6:00am and be automatically exported to a C drive folder. Is this possible in PL/SQL, or will this
I don't think this is possible using only PL/SQL Developer.
Some options I can think of:
  • Use Windows' "Scheduled Tasks" in combination with a SQL script run by SQL*Plus or possibly PL/SQL Developer.
  • Use "Scheduled Tasks" in combination with a Perl (or Python, or whatever) script that connects, does the query, and writes the result to file.
  • Use DBMS_JOB or DBMS_SCHEDULER and create a job in the database that runs the query and then uses UTL_FILE to write the result to a file.
Personally I would use the first option. Also, this may be helpful.
