PL SQL Developer V15, DBMS Scheduler Timestamp Problem
mfuessel
I'm using PL/SQL Developer Version 15.0.2.2054 (64 bit) and have currently the following problem with the DBMS Scheduler Tool.
When I change the Start date for example from "02.10.2018 15:49:33,000000 EUROPE/BERLIN" to "01.10.2022 15:00:00,000000 EUROPE/BERLIN" and hit Apply, following error will occur:
"Could not convert variant of type (UnicodeString) into type (Currency)."
In the preferences -> Oracle -> Options: "Use timestamp format for scheduler objects" is checked.
In PL/SQL Developer Version 13 the error did not occur.
Does anyone else have this problem or even a solution for it?
Is this a known issue?
Thank You
