M mike Member³ Mar 29, 2017 #1 I cannot copy from the output of PL/SQL Developer reports. Prior versions used to allow that. Is there something I can do to be able to copy from the output? Thanks! Mike
Marco Kalter Administrator Staff member Mar 30, 2017 #1 You can make a selection, right-click on it, and select "Copy". Does this not work for you?
M mike Member³ Mar 30, 2017 #1 Yes - that works! Thank-you. I was doing Ctl-C or edit/copy from the menu. I'm fine with right clicking.
