pl/sql developer ora-01001: invalid cursor
Bruce Carson
We run cursors within our select statements all the time. Recently it stopped working and am not sure why. The following query isn't a query we are running but does demonstrate the issue.
Execute the following query in a sql window:
select t.table_name,
cursor (select c.column_name
from user_tab_cols c
where c.table_name = t.table_name) as columns
from user_tables t;
The query returns the following output:
PLSQL_PROFILER_RUNS
PLSQL_PROFILER_UNITS
PLSQL_PROFILER_DATA
STAFF_TR1
STAFF
LOAD_FROM_ICM_BASELINE_TMP
When I click the box next to the to see the contents of the cursor a new window opens but I get the error ora-01001: Invalid Cursor. The strange thing is this used to work but something has changed to give this error.
Environment as follows:
PL/SQL Developer 7.0.3.1123
Oracle Database 10g Enterprise Edition Release 10.2.0.2.0 - 64bi
PL/SQL Release 10.2.0.2.0 - Production
TNS for IBM/AIX RISC System/6000: Version 10.2.0.2.0 - Productio
NLSRTL Version 10.2.0.2.0 - Production
This works fine for me. To obtain some more diagnostic information, can you modify the shortcut and add the debugsql parameter? For example:
i have a similar problem.
The original select works for me too, but if I add a where-clause to the outer select, I get also an ora-01001 when trying to open the cursors.
Example:
from user_tables t where t.table_name = 'MYTABLE';
In sqlplus this select works.
PL/SQL Developer Version 7.0.3.1123.
No solution yet. Haven't had much chnace to work on this and the users have learned to live without it (they are not happy but are surviving).
This fails with ORA-01001 for me too. We'll check it out.
Marco,
Have you guys found a solution to this problem? I amd getting the same error in PL/SQL Dev version 7.1.1.1339.
I'm running the same query:
Originally posted by Marco Kalter:
No, we don't have a solution yet. It might be an Oracle bug.
According to me it doesn't seem to be an Oracle bug. I tested it on Oracle9i Enterprise Edition Release 9.2.0.7.0 - 64bit and Oracle Database 10g Enterprise Edition Release 10.2.0.3.0 - 64bit using PL/SQL Developer 6.0.6.947 and TOAD 8.6.1.0.
On both databases using PL/SQL Developer I get the ORA-01001 error. When I use TOAD with the same query then there is no problem. Both tools use the same Oracle Client software.
