PL/SQL developer in Delphi 7
JOA
I recently upgraded our PL/SQL developer version and on one of the pc's now I get the message
Error opening PL/SQL developer ("C:\program files\PLSQL Developer\plsqldev.exe" "%1")
You need to have a properly installed version available
But... PL/SQL developer is working fine on this pc, except when opened from within Delphi7.
The version which we used before didn't have this problem, so I suspect there is an old reg setting somewhere.
Any idea what could cause this?
Thanks!
Can you start regedit.exe and change the following key?
HKEY_CLASSES_ROOT
  PL/SQL Developer
    Shell
      Open
        Command
Remove "%1" at the end of the value.
