PL/SQL developer hangs upon Right clicking on Procedure, package, function
iratta
Version 7.1.5.1398 (100955.957)
When i right click on a procedure/function of any schema in a particular instance, the whole pl/sql developer program hangs. But i can right click and debug procs,packages on any other schema in any other instance.
Why is this happening?
here is the output
PL/SQL Developer
Version 7.1.5.1398
Windows 2003 Standard Edition 5.2 Build 3790 (Service Pack 2)
Physical memory : 2,086,916 kB (915,748 available)
Paging file : 4,031,188 kB (2,794,348 available)
Virtual memory : 2,097,024 kB (2,019,580 available)
Parameters
debugsql
Preferences
Session mode: Multi
OCI Library:
Use OCI7: False
Preference Files
Plug-Ins
19/02/2009 11:46:07 Application started
19/02/2009 11:46:07 InitPreferences
19/02/2009 11:46:07 Load C:\Program Files\PLSQL Developer\Preferences\Default = 0
19/02/2009 11:46:07 PreferenceSet.Load C:\Program Files\PLSQL Developer\Preferences\Default\Default.ini
19/02/2009 11:46:07 PreferenceSet.Load OK
19/02/2009 11:46:07 Determine LocalPrefPath
19/02/2009 11:46:07 [1]: C:\Program Files\PLSQL Developer\Preferences
19/02/2009 11:46:07 LocalPrefPath: C:\Program Files\PLSQL Developer\Preferences\amanu
19/02/2009 11:46:07 Load C:\Program Files\PLSQL Developer\Preferences\amanu = 0
19/02/2009 11:46:07 PreferenceSet.Load C:\Program Files\PLSQL Developer\Preferences\amanu\default.ini
19/02/2009 11:46:07 PreferenceSet.Load C:\Program Files\PLSQL Developer\Preferences\amanu\user.prefs
19/02/2009 11:46:07 InitPreferences end
19/02/2009 11:46:07 SortPreferenceSets
19/02/2009 11:46:07 - Default Amanu
19/02/2009 11:46:07 - System Default
19/02/2009 11:46:07 pfReadRegistry(PL/SQL Developer\Shell\Open\Command, )
19/02/2009 11:46:07 ReadString OK
19/02/2009 11:46:07 pfReadRegistry: "C:\Program Files\PLSQL Developer\plsqldev.exe" "%1"
19/02/2009 11:46:07 LoadPreferences
19/02/2009 11:46:07 LoadPreferences searching for default
19/02/2009 11:46:07 C:\Program Files\PLSQL Developer\Preferences\amanu\default.ini
19/02/2009 11:46:07 LoadPreferences NewPref := nil
19/02/2009 11:46:07 LoadPreferences Reading preferences
19/02/2009 11:46:07 LoadPreferences ReadPosition
19/02/2009 11:46:07 LoadPreferences ToolsBrowserItemClick(nil)
19/02/2009 11:46:07 LoadPreferences CreateBrowserFilters...
19/02/2009 11:46:07 LoadPreferences Files
19/02/2009 11:46:07 LoadPreferences Logon
19/02/2009 11:46:07 LoadPreferences Buttons
19/02/2009 11:46:07 LoadPreferences Printer
19/02/2009 11:46:07 LoadPreferences BrowserFolders
19/02/2009 11:46:07 LoadPreferences end
19/02/2009 11:46:07 MacroLibFilename: C:\Program Files\PLSQL Developer\Macro\amanu.lib
19/02/2009 11:46:17 TOracleSession PLSQLDevForm.Session Start Session.LogOn as ADDR2006R10QA@ORA214
19/02/2009 11:46:17 TOracleQuery BytesPerCharacterQuery Start Query.Execute
19/02/2009 11:46:17 TOracleQuery BytesPerCharacterQuery End (1 record processed)
Duration = 0.016
Duration = 0
19/02/2009 11:46:17 TOracleQuery Query Start Query.Execute
19/02/2009 11:46:17 TOracleQuery Query End (1 record processed)
Duration = 0
19/02/2009 11:46:17 TOracleSession PLSQLDevForm.Session End
Duration = 0.156
19/02/2009 11:46:17 LogonHistorySave start
19/02/2009 11:46:17 ChangeUserPref LogonHistory,
19/02/2009 11:46:17 ChangeUserPref DSA,
19/02/2009 11:46:17 ChangeUserPref end
19/02/2009 11:46:17 ChangeUserPref ColumnAssociations,
19/02/2009 11:46:17 ChangeUserPref ImportAssociations,
19/02/2009 11:46:17 ChangeUserPref BrowserFilters,
19/02/2009 11:46:17 ChangeUserPref BrowserFolders,
19/02/2009 11:46:18 ChangeUserPref end
19/02/2009 11:46:18 ChangeUserPref SessionQueries,
19/02/2009 11:46:18 ChangeUserPref ExternalTools,
19/02/2009 11:46:18 ChangeUserPref Documents,
19/02/2009 11:46:18 ChangeUserPref Reports,
19/02/2009 11:46:18 LogonHistorySave end
19/02/2009 11:46:18 FormCreate Session.Connected
19/02/2009 11:46:18 FormCreate Logon.Executed -1
19/02/2009 11:46:18 FormCreate TDBNames.Make
19/02/2009 11:46:18 FormCreate SessionChanged
19/02/2009 11:46:18 TOracleQuery Query Start Query.Execute
SQL = select * from v$version
19/02/2009 11:46:18 TOracleQuery Query End (5 records processed)
Duration = 0
19/02/2009 11:46:18 SessionChanged SetDBAViews
19/02/2009 11:46:18 TOracleQuery $02D2C730 Start Query.Execute
19/02/2009 11:46:18 TOracleQuery $02D2C730 End (0 records processed)
Duration = 0
Duration = 0.016
19/02/2009 11:46:18 SessionChanged Authorizations.Load
19/02/2009 11:46:18 TOracleQuery $02D2C5D0 Start Query.Execute
sys.plsqldev_authorization
19/02/2009 11:46:18 TOracleQuery $02D2C5D0 End
Duration = 0.016
19/02/2009 11:46:18 SessionChanged EnableAuthorizedMenus
19/02/2009 11:46:18 TOracleSession $03650EA0 Start Session.LogOn as ADDR2006R10QA@ORA214
19/02/2009 11:46:18 TOracleQuery Query End (1 record processed)
Duration = 0
19/02/2009 11:46:18 TOracleSession $03650EA0 End
Duration = 0.094
19/02/2009 11:46:18 SetSessionAction starts: Main session
19/02/2009 11:46:18 TOracleQuery $02D2C890 Start Query.Execute
from sys.user_objects o
SQL = select null from dual
19/02/2009 11:46:18 TOracleQuery $02D2C890 End (100 records processed)
Duration = 0
19/02/2009 11:46:18 TOracleQuery $02D2C730 End (1 record processed)
Duration = 0
19/02/2009 11:46:18 TOracleQuery $02D2C890 Start Query.Next for up to 100 records
:ACTION = Main session
Duration = 0.015
Duration = 0
19/02/2009 11:46:18 SetSessionAction ends
Duration = 0
19/02/2009 11:46:18 ExecuteConnectScript starts
19/02/2009 11:46:18 ExecuteConnectScript ends
Duration = 0
19/02/2009 11:46:18 TOracleQuery PLSQLDevForm.DynamicQuery Start Query.Execute
19/02/2009 11:46:18 TOracleQuery PLSQLDevForm.DynamicQuery End (1 record processed)
Duration = 0
Duration = 0
19/02/2009 11:46:18 SessionChanged LoadRecentObjects
19/02/2009 11:46:18 SessionChanged Notify children
Duration = 0.016
19/02/2009 11:46:18 SessionChanged Logoff secondary sessions
19/02/2009 11:46:18 SessionChanged SessionMode = smMulti
19/02/2009 11:46:18 SessionChanged EnableChildFunctions
Duration = 0.016
OracleHomeKey: SOFTWARE\ORACLE\KEY_OraDb10g_home2
OracleHomeDir: C:\oracle\product\10.2.0\db_2
Found: oci.dll
Using: C:\oracle\product\10.2.0\db_2\bin\oci.dll
Duration = 0
SQL = select value from sys.nls_database_parameters where parameter = 'NLS_CHARACTERSET'
Duration = 0
Duration = 0
Duration = 0
19/02/2009 11:46:18 TOracleQuery $02D2C890 End (84 records processed)
Duration = 0
from all_synonyms s,
sys.all_objects o
and o.owner = s.table_owner
19/02/2009 11:46:18 TOracleQuery PLSQLDevForm.PlugInQuery Start Query.Execute
SQL = Select banner from sys.v_$version where upper(banner) like upper('%Oracle%')
19/02/2009 11:46:18 TOracleQuery PLSQLDevForm.PlugInQuery End (1 record processed)
Duration = 0
SQL = select count(*) from user_role_privs where granted_role like 'DBA' and default_role like 'YES'
Duration = 0.016
SQL = select count(*) from user_sys_privs where upper(privilege) like upper('DROP USER')
Duration = 0.109
Duration = 0
Duration = 0.016
Duration = 0
SQL = select count(*) from user_sys_privs where upper(privilege) like upper('ALTER ANY CLUSTER')
Duration = 0.016
Duration = 0.015
Duration = 0
Duration = 0.016
SQL = select count(*) from user_sys_privs where upper(privilege) like upper('DROP ANY TABLE')
Duration = 0
Duration = 0
Duration = 0
Duration = 0.016
Duration = 0
19/02/2009 11:46:18 SortPreferenceSets
19/02/2009 11:46:18 - Default Amanu
19/02/2009 11:46:18 - System Default
Duration = 0.016
19/02/2009 11:46:19 TOracleQuery $02D2C890 End (100 records processed)
Duration = 0
19/02/2009 11:46:19 TOracleQuery $02D2C890 Start Query.Next for up to 100 records
Duration = 0.015
Duration = 0
19/02/2009 11:46:19 TOracleQuery $02D2C470 Start Query.Execute
19/02/2009 11:46:19 TOracleQuery $02D2C470 End (0 records processed)
Duration = 0
Duration = 0.016
Duration = 0
Duration = 0.016
Duration = 0.016
Duration = 0
19/02/2009 11:46:19 WMUpdatePopups starts
19/02/2009 11:46:19 LoadDesktop starts
19/02/2009 11:46:19 LoadDesktop ends
Duration = 0
19/02/2009 11:46:19 WMUpdatePopups ends
Duration = 0.016
Duration = 0
Duration = 0
Duration = 0.016
Duration = 0
19/02/2009 11:46:19 TOracleQuery $02D2C890 End (27 records processed)
Duration = 0.016
19/02/2009 11:46:19 TOracleSession $03650EA0 Start Session.LogOff
19/02/2009 11:46:19 TOracleSession $03650EA0 End
Duration = 0
19/02/2009 11:46:21 TOracleQuery PLSQLDevForm.ObjectQuery Start Query.Execute
SQL = select object_name, owner object_owner, status, object_type, created, last_ddl_time
from sys.all_objects o
where object_type = 'PROCEDURE'
and object_name not like 'BIN$%'
order by decode(owner, user, 0, 1),
owner,
object_name
:OBJECT_TYPE = PROCEDURE
:EXTRA_CONDITION =
19/02/2009 11:46:25 TOracleQuery PLSQLDevForm.ObjectQuery End (100 records processed)
Duration = 3.688
19/02/2009 11:46:25 TOracleQuery PLSQLDevForm.ObjectQuery Start Query.Next for up to 100 records
19/02/2009 11:46:25 TOracleQuery PLSQLDevForm.ObjectQuery End (5 records processed)
Duration = 0
19/02/2009 11:46:37 TOracleQuery $02D2C470 Start Query.Execute
SQL = select debuginfo
from sys.all_probe_objects po
where po.owner = 'ADDR2006R10QA'
and po.object_name = 'C_FORCE_PARCL_SINGLE_TO_CHUTES'
and po.object_type = 'PROCEDURE'
:OBJECT_OWNER = ADDR2006R10QA
:OBJECT_NAME = C_FORCE_PARCL_SINGLE_TO_CHUTES
19/02/2009 11:46:37 TOracleQuery $02D2C470 End (1 record processed)
Duration = 0.125
19/02/2009 11:46:37 TOracleQuery PLSQLDevForm.PlugInQuery Start Query.Execute
SQL = --
-- you must have granted select on sys.v_$db_object_cache
select decode(kept,'YES','UnKeep','Keep') caption
from sys.v_$db_object_cache
where owner like 'ADDR2006R10QA'
and name like 'C_FORCE_PARCL_SINGLE_TO_CHUTES'
and type like 'PROCEDURE'
union
select 'Keep' caption from dual
order by 1 desc
19/02/2009 11:46:58 TOracleQuery PLSQLDevForm.PlugInQuery End (1 record processed)
Duration = 20.438
19/02/2009 11:46:58 TOracleQuery PLSQLDevForm.PlugInQuery Start Query.Execute
SQL = select status
where owner = 'ADDR2006R10QA'
and object_name ='C_FORCE_PARCL_SINGLE_TO_CHUTES'
Duration = 0.11
19/02/2009 11:46:58 AddPlugInPopups Start 3
19/02/2009 11:46:58 Active Query Builder
19/02/2009 11:46:58 Browser Extender version 2.0 by Joachim Rupik
19/02/2009 11:46:58 Index
19/02/2009 11:46:58 Table
19/02/2009 11:46:58 User
19/02/2009 11:46:58 Tablespace
19/02/2009 11:46:58 Function
19/02/2009 11:46:58 Package
19/02/2009 11:46:58 Package body
19/02/2009 11:46:58 PROCEDURE
19/02/2009 11:46:58 AddMenu
19/02/2009 11:46:58 AddMenu Keep
19/02/2009 11:46:58 Sequence
19/02/2009 11:46:58 Trigger
19/02/2009 11:46:58 Type
19/02/2009 11:46:58 Type body
19/02/2009 11:46:58 Database link
19/02/2009 11:46:58 Directory
19/02/2009 11:46:58 Foreign Key
19/02/2009 11:46:58 Primary Key
19/02/2009 11:46:58 AddMenu >>> VALID > VALID > VALID
As a test, can you modify the shortcut and add the noplugins parameter and try again? For example:
"C:\Program Files\PLSQL Developer\plsqldev.exe" noplugins
Let me know if this helps.
