PL/SQL Developer 16.0 Beta 4 released
Status
Not open for further replies.
Administrator
Staff member
We have released PL/SQL Developer 16.0 Beta 4 with the following enhancements:
  • Accessing View objects could cause an Access Violation
  • FOR loops could cause PL/SQL Beautifier / Parser errors
  • Preference "Export to Excel with Text Formatting" added (default on)
  • Preference Search could cause Access Violations
  • Window List text could be misaligned when status icons were disabled
  • Connection List could display an "Invalid Index" error
  • Program Window declaration hint could display too much text
  • FTP Plug-In could cause Access Violations
  • Splash screen could incorrectly show "Loading Workset"
  • IDE Layout is now preserved even if AutoSave Desktop is disabled
  • Leaving Full Screen mode would not restore all dockable tools correctly
  • Improved error handling when exporting rows to Excel
  • The Code Assistant now also provides an (all) option and multi-select for inline view field lists
  • Object functions "Properties" and "Describe" did not properly handle errors
  • Compare User Objects and Compare Table Data did not handle target session logoff errors correctly
  • Buttons with a dropdown list did not have the correct visual style in dark mode
It can be downloaded here.
Status
