PL/SQL Developer 13.0 Beta 7 released
Status
Not open for further replies.
Administrator
Staff member
We have released Beta 7 32 bit and Beta 7 64 bit with the following fixes and enhancements:
  • If the Code Assistant Filter Method preference is "Contains", the (all) items was not always at the top
  • Table.column highlighting did not work when using SQL operators like IN, CASE, AND, OR.
  • Table.column highlighting could incorrectly highlight function calls
  • Table.column highlighting did not work correctly when the cursor is on a table.column expression in a subselect
  • Find & Replace Selection scope did not always work correctly when using "Replace All"
  • SQL Window editor text was not always updated in Query By Example mode
  • Indicator color defined for a connection did not always work
  • Deleting & unindenting at the end of a line now leaves an extra space if necessary
  • Cursor parameter highlighting was not always correct
Status
