PL/SQL Beautifier and fetch into
Henk Jan
I am using version 7.1, but the problem exits for some time.
The following PL/SQL statement is not correctly beautified:
  open c(p_id);
  fetch c into rec;
  close c;
is beautified into
  open c(p_id);
  fetch c
    into rec;
  close c;
As you can see the into part of the fetch statement is not aligned. Not to the left and not to right.
I set left align keywords within the DML tab.
Is there anyway I can align this construction correctly? The code should be:
  open c(p_id);
  fetch c
  into  rec;
  close c;
or
  open c(p_id);
  fetch c
   into rec;
  close c;
There is currently no option that controls this. I have added it to the list of enhancement requests though.
I'd like to second this request for control over the 'fetch into', though what I want is to be able to place it on one line.
( I see there are requests for this from way back in 2003, so I won't hold my breath :) )
Guttorm
