Performance of PSD 12 Test Window with code Errors
Benjamin L
Performance in test windows is a bit ugly while compiling the code. When you try to compile code with any error in PSD 11 it needs 2 seconds to compile in PSD 12 about 10 seconds
Test Code:
DECLARE
lsTest;
END;
Can you let me know how executing this PL/SQL Block is related to compilation with errors? Is the lsTest object invalid and/or are any of its referenced objects invalid? Are they invalid because of errors or because of a change in a referenced object?
This was just an example for nonsense code, which results in an error. You can also try
Paste this code in a test window and try to start...
Response is instantaneous in this case.
I also noticed this big delay on my PC (Windows 10, 64 bit Developer) with Oracle 11.2 DB
Update: I installed 32bit version of PSD 11.0.6 and the speed increase is quite big, not only in the Test window but even the normal SQL:
'select 1 from dual' takes 0.368s in PSD12_64 and 0.017s in PSD11_32
Update2: tested PSD 12 32bit and it is as slow as 64bit version
