Gary Eckhardt
I'm currently debugging a sql statement, and I need to set up a variable like 'ABCDE','FGHIJ','KLMNO'.... etc, with the quotes and the commas in the string. Everything I've tried so far has given me a ORA-01036. The section that the variable, "lContributions" is used as such:
First off, does the test window all me to pass in a variable this way, with the quotes and commas in the string, or should it be written a different way? Is there any way of seeing the actual variable replacements in the code so I can see if it's a coding issue?
Thanks.
(select *
from (select trim(substr(txt,
instr(txt, ',', 1, level) + 1,
instr(txt, ',', 1, level + 1) -
instr(txt, ',', 1, level) - 1)) as token
from (select ',' || lContributions || ',' as txt from dual)
connect by level <=
length(txt) - length(replace(txt, ', ', '')) - 1))
Thanks.
