OracleObject variable and ClientDataSet parameters
Roeland
How do i set TOracleObject Variables in the Param list of my ClientDataSet?
Example:
In my OracleDataSet.SQL:
array_exmple.view_col(p_cursor => :cursor,
p_array => :p_array);
I defined p_Array as an Object.
Then i linked a DataSetProvider and a ClientDataSet to the OracleDataSet.
Now, when i do "Fetch Params" my p_Array variable becomes a p_Array INTEGER parameter? :confused:
How can i solve this problem?
This is not supported. Only scalar parameters are supported. You will need to create a specific procedure to get this array from the server to the client.
