Oracle 12c DBMS_SQL.RETURN_RESULT with pl/sql dev 11
sparinfo
With pl/sql dev 11, I execute the Oracle 12c new feature DBMS_SQL.RETURN_RESULT.
Exemple :
declare
l_cur sys_refcursor;
open l_cur for select * from dual;
dbms_sql.return_result(l_cur);
It works without error, but I don't see the results. Where I can see the results in pl/sql dev 11 ?
Thanks.
Implicit results are supported in the Test Window. If you execute a Test Script that creates implicit results, a cursor variable will be added for each result set. You can subsequently click on the implicit cursor variable value button to view the results, just like with normal cursor variables.
