ORA-04044: procedure..............
Larry A
While trying to use the famours Data generator, i ran into the following error massage ORA-04044: procedure..............
The input paramenter is List(select field from table).
Need HELP!!!!
Regards,
Larry
Hello Again,
Can you please ignore the above massage - i've figured out what the problem was(User error!!!).
