More Problems with custom linked queries (10.0.5.1710)
he
Thank you for fixing Problem with custom linked queries when no foreign key constraints defined. But I'v found two more problems with this new feature:
1) If you selected only views, then the new function "custom linked query" is not available. The "Linked Query" button shows simply no submenu. Please provide this for views also.
2) Some of our tables have a column NR (for primary key). If you use the "custom linked query" from a query on such a table by referencing :m_nr and then make a cascaded linked query from the linked query and want to use :m_nr variable again, than the second linked query will always provide no result. I assume that the :m_nr variable has always the value from the first linked query.
Do you have a solution for cascaded custom linked queries?
Thanks, he.
