Stew Stryker
I've been using the Connection->Store with password feature for years. (Yes, I know it's not exactly safe.)
We have recently started using longer passwords, up to 16 characters. It seems like PSD will not save connections with these longer passwords. I can still save shorter passwords and re-use them. But the long ones can't be used again once you exit PSD and restart. I guess the connection data gets saved when you exit?
We are running PSD V 10.0.5.1710
Stew
Stew
