Stew Stryker
Ever since I upgraded to 9.0.0.1601 of PSD, I've started getting the above error when I either try to connect to the database or run the first query/update after connecting. The problem is that it's very sporadic. I haven't found an exact case when it always happens.
I had the new "Allow multiple connections" feature turned on, and I really liked it, but I think that's what's causing this error??? I was letting PSD store my login history with passwords, so I thought it should always have the complete connection information.
I've used the Reconnect Plug-In for years, but I thought maybe that's conflicting with the new Multiple Connections feature. But I still have the problem even after disabling the plug-in. (I haven't tried uninstalling it.)
If I turn off the "Allow multiple connections" feature and restart PSD, I still get the error if I try to log in from the initial login prompt. When I use the Session->Set Main Connection->Imported Fixed History (which includes passwords), it fails about 50% of the time.
Is anyone else seeing this problem?
Suggestions?
BTW, even after turning off "Allow multiple connections", the Session->Set Main Connection menu still displays, which I would expect to be turned off?
Stew
Suggestions?
Stew
