macro key shortcut in 6.0.0.840
Buckeye
I was using the latest version 5 as a licenses user and installed the trial of 6 on top of 5. I lost my macro. I created it again and can add it to a buttom but can't seem to get the shortcut key to save in the preferences.
Did you add the macro to the menu and assign a function key via Tools > Preferences > User interface/Key configuration?
Sorry took me so long to get back...
I click the record button, type some things in that I want recorded. I click the flashing record button. I click the macro library button and nothing is there, even nothing on the keys tab.
Oh, I got it. Next, click new in the macro library. Now the keys tab has my stuff on it.
Either my intuition is bad or it is not intuitive enough. :-) In either case, it DOES work.
I also have the new version installed but I can not define new macro anymore: the "new macro" is disabled in macro library!?
any idea?
Thanks.
You first need to record a macro before you can add it to the library with teh "New" button. I agree that it is not intuitive enough...
