Lower case column names
If I create a table with lower case column names like "Description", PL/SQL Developer does not handle this correctly in Edit Data window and other places too. For example, try creating a "Product" table, and then go right click and Drop it through the Browser... it does not work.
It seems to me, that PL/SQL Developer tries to reference PRODUCT and not "Product".
Is there a preference I can tweak, or is this a problem? If it is a problem, could you fix it please?
I didn't need this feature from Oracle, but now that I am using a tool that automatically creates my schema and uses quotes around column and table names, I really need PL/SQL Developer to able to handle this situation.
Thank you,
Petros
Any news regarding my request? I noticed this problem has not been resolved in the latest release.
I am sure you are working hard on more critical problems so I understand why you might not choose to address the problem.
I would be happy if you could give me an estimate: Are you going to address the problem in a minor release or in the next major release?
Thank you,
Petros
I hate to necro this thread but its been 8 years and I still see no answer to this. I am on version 7.1 and PL/SQL Developer is STILL having this issue....is there an option im missing somewhere that was added in?
