Long running test scripts never end
dgs!
I have version 9.0.6.1665 of PL/SQL developer. I have noticed that long running test scripts fail to complete. The task completes, however the test window still seems to think that is is running.
What can I do to make the test window finish when the task that it is running completes?
Just a thought...
Does your test script use a lot of dbms_output? In that case, PLD can take forever to complete showing the output, as it fetches one line at a time from the database. Maybe try to disable output and try again?
Interesting thought, but I'm using Application_Info instead of dbms_output.
It may a communication issue. I'm a remote developer and I have a lot of problems with Time Warner Cable.
