Logon window instead of Oracle logon
Jens Balk
every time I start plsqldev.exe I get the following window:
How can I prevent that?
I would like to get the following window:
System: Windows XP, Version 9.0.0.1601
regards
Jens
You can use the NoConnectionList command-line parameter. For example:
"C:\Program Files\PLSQL Developer\plsqldev.exe" NoConnectionList
You can also set this in the params.ini file in the PL/SQL Developer installation directory:
# Suppress the connection list at startup and display
# the old style logon dialog instead:
NoConnectionList=1
