joness59
We have a test RAC and one of the databases on the RAC is DEV. When I try to connect using the connect string jonesst@:: I get the error ORA-12545 Connect failed because target host or object does not exist. When I use the same connect string in SQL*Plus it works just fine. It appears PL/SQL Developer is doing something with the connect string which causes it not work. I also tried this on a single instance database and get the same results.
