Issue while querying/trying to get get metadata
Joby M
I am using PL/SQL Developer Version 7.1.1.1339
for accessing Oracle Database 11g Enterprise Edition Release 11.1.0.7.0.
While trying to type in a query with synonym name
(Eg :- typing in select * from my_synonym)
OR Right clicking mouse on an object's synonym
(Eg :- Right click on package's synonym name for viewing source)
I am getting the below error in a message window
ORA-01436: CONNECT by loop in user data
ORA-06512: at line 59
It is a bit annoying, while this comes multiple times out while working on some code.
Does somebody have a solution for this ?
