Issue: Truncated Output in PL/SQL Developer with UTF‑8 Client and WE8MSWIN1252 Database
nic
we are encountering the following issue after migrating our source files to UTF‑8 encoding.
As part of this migration, we set the NLS_LANG environment variable to .AL32UTF8. However, the Oracle databases we connect to are still using the WE8MSWIN1252 character set.
PL/SQL Developer appears to handle the input correctly in this configuration: SQL statements written in UTF-8 are properly converted to WE8MSWIN1252 when sent to the database. We do not see any issues here here with the SQL that is received by the database.
The problem occurs with the output shown by PL/SQL Developer. When executing these files or interactively input these SQL commands in either the SQL Window or the Command Window, the output is truncated. Parts of the expected output seem to be missing, as if characters were being swallowed or cut off during display.
I have attached screenshots that show the SQL input and resulting output in both the SQL Window and the Command Window.
Additionally, please find the PL/SQL Developer Support Info output attached below:
PL/SQL Developer
  Version 16.0.8.2176  (64 bit)
  01.154269 - Unlimited user license
  Service Contract: 01.05.2023
  Style: Sky
  Windows 10 Build 17763
  en-US(1033)/English (United States)
  Physical memory : 201.326.068 kB  (180.196.900 available)
  Paging file     : 220.916.208 kB  (192.989.248 available)
  Virtual memory  : 137.438.953.344 kB  (137.433.951.208 available)
Parameters
  C:\Program Files\PLSQL Developer 16\plsqldev.exe
  nosplash
  prefpath=Z:\tmp\blub
Preferences
  Session mode: Multi
  OCI Library: <none>
  Use OCI7: False
Preference Files
  \\cifs\TSProfile\Userdata\n\AppData\Roaming\PLSQL Developer 16\Preferences\default\Default.ini
  Z:\tmp\blub\n\default.ini
License File
  C:\ProgramData\PLSQL Developer\aalf.dat
Debug file
  \\cifs\TSProfile\Userdata\n\AppData\Roaming\PLSQL Developer 16\plsqldev.log
Plug-Ins
  *Active Query Builder (1.5.1) (C:\Program Files\PLSQL Developer 16\PlugIns\ActiveQueryBuilder.dll)
  *PL/SQL Documentation (1.4.1) (C:\Program Files\PLSQL Developer 16\PlugIns\plsqldoc.dll)
   (* is Active)
Enabled AI Systems
  OpenAI GPT
Aliases
Homes
  OH1939595010  (D:\app\oracle\Middleware\frt11g\frhome)
  OH416195435  (D:\app\oracle\Middleware\frt11g\oracle_common)
  OraClient19Home1  (D:\devtools\Oracle\product\19.0.0\client_1)
DLLs
  D:\devtools\Oracle\product\19.0.0\client_1\bin\oci.dll
TNS File
  D:\devtools\tns_admin\tnsnames.ora
Using
  Home: <Instant Client>
  DLL: D:\devtools\instantclient_23_0\oci.dll
  OCI: version 12.1  (23.26.0.0.0)
  Oracle Database 19c Enterprise Edition Release 19.0.0.0.0
Character Sets
  Character size: 1 byte(s)
  CharSetID: 873
  NCharSetID: 2000
  Unicode Support: True
  NLS_LANG: .AL32UTF8
  NLS_CHARACTERSET: WE8MSWIN1252
Process
  Working Set = 165.765.120
  Memory = 40.319.424
  GDI Objects = 632
  User Objects = 409
  Handles = 752
Monitor
  PixelsPerInch = 96
  Id = 0
  PPI = 96
  Primary = True
  Handle = 65537
  Left = 0
  Top = 0
  Width = 3838
  Height = 2079
  MainFormOnTaskbar = True
Is this a known issue?
Kind regards,
Nico
Thank you very much for the quick response. I have already tested the update, and the issue no longer occurs. It’s great to see support requests being handled so quickly—something that unfortunately isn’t the case with many companies. Many thanks and compliments from my side.
