Is there a way to backup preferences
SaKa
Just want to see if there is a way to backup the Preferences and layout (save layout),and saved Passwords. I mean like the export function of the favourites in IE.
Its just that I had a crash on my machine I had to reinstall everything and still the PLSQD is not quite how I had it before :)
Sak
Version 12.0.1.1814 (32 bit)
You can backup the following directory:
%APPDATA%\PLSQL Developer 12
All preferences and other configuration data is stored here. You can additionally use regedit.exe to export the following section:
HKEY_CURRENT_USER\Software\Allround Automations\PL/SQL Developer 12
This section contains dynamic information such as recent file lists, search history, window sizes, and so on.
No the passwords are stored in your Connections - see my reply to your other post about how to Export connection definitions (including passwords)
