Mauro Sousa
I'm facing problems when testing some kind of functions.
Basically on test window, i'm unable to open the results from a cursor when this cursor is built from a table_table_varchar.
Example:
o_title OUT pk_types.cursor_type
and casting before return:
OPEN o_title FOR
SELECT column_value FROM TABLE(CAST(l_title_array_t AS table_table_varchar));
When this is just a table_varchar and not a table_table_varchar everything works.
Another note: I'm getting the proper results because i've a webservice where i can see the requested data, but not on PL/SQL Software
Thanks for any help
Mauro Sousa
Example:
OPEN o_title FOR
Thanks for any help
Mauro Sousa
