How to pass 2 sql statement at same time..
TMoore
Hi
I wrote this:
select count(1) from test;
select * from test;
developer hang on ';' character. How to solve this problem? Sometimes I have long script whitch can not union select.
What you you expect as result of this both queries ?
Two different result panes ?
Why don't you use a second window for the second query ?
There is an option under Tools / Preferences / SQL Window called AutoExecute Queries. Check it and when you click Execute PLSD will select the closest query and execute it.
>What you you expect as result of this both >queries ?
It is one of the solution. I don't what to use second program window. I have 8 queries, each has 10 - line of code.
> Auto-execute and Auto-select is good and also mark some sql and fire it.
I can write union select but it costs much more cpu time.
How to present this results, maybe it could be represents on each tab. It's great idea.
