How Do u Declare a boolean?
kstyle
Hi there,
This is real basic question but for some reason i am having some real problems with it. I have the following code, and when i run it, it comes with the folowing error:
Code snippit:
create or replace type Line_c01ksp as object (
y1 number,
y2 number,
y3 number,
y4 number,
x1 number,
x2 number,
x3 number,
x4 number,
a1 number,
a2 number,
b1 number,
b2 number,
c1 number,
xc number,
yc number,
num number,
denom number,
r1 number,
r2 number,
r3 number,
r4 number,
asign boolean,
bsign boolean,
member function getStart return Pnt_c01ksp,
member function getFinish return Pnt_c01ksp,
member function intersectsLL(l1 Line_c01ksp, l2 line_c01ksp) return CrossOverResult_c01ksp
ERRoR MESSAGE:
29/7 PLS-00530: Illegal type used for object type attribute:
'BOOLEAN'.
30/7 PLS-00530: Illegal type used for object type attribute:
'BOOLEAN'.
could some please tell me wot im doin wrong???
Thank you for your time.
kstyle.
First of all, you posted this question 4 times ;)
A database type can only hold database type variables. So you can use Varchar2, Number etc. But you can't use any PL/SQL Types, like Boolean, PLS_Integer etc.
Hope this helps,
Patrick
Originally posted by kstyle:
Hi there,
Code snippit:
y1 number,
y2 number,
y3 number,
y4 number,
x1 number,
x2 number,
x3 number,
x4 number,
a1 number,
a2 number,
b1 number,
b2 number,
c1 number,
xc number,
yc number,
num number,
denom number,
r1 number,
r2 number,
r3 number,
r4 number,
asign boolean,
bsign boolean,
ERRoR MESSAGE:
'BOOLEAN'.
'BOOLEAN'.
kstyle.
The reason for this unlucky bejavior is that oracle implemented the OO Feature not in PL/SQL but in SQL ( Two execution engines );
and put a little bit PL/SQL arround it for methods;
But you can define a Method which return true /false depending on a number -val of a data member 0/1
Carl
