Hello, everybody.
May be I've found a bug in the "View/Create Table" window (PL/SQL Developer, Version 7.0.3.1123): a table index using an object type attribute is not displayed.
test case
(1) object type
(2) table and index
(3) "View Table"
Display the table and it's indexes using the "View Table" window (object browser, table "sometab" -> context menu -> view -> tab "Indexes"), the index "sometab_ix" is missing. As well, the sql script (button "View SQL) does not mention the index.
(4) browser and user dictionary
But the index does exist. You find it in the object browser and in the user dictionary:
displays the index and it's three columns:
Kind regards
Ww
test case
(1) object type
create or replace type t_someobj as object(
somekey varchar2(6)
, somedate date
, member function isempty return boolean
create table sometab(
someid number not null
, somecode varchar2(4) not null
, someobj t_someobj
create index sometab_ix on sometab
( someid
, somecode
, someobj.somedate
select index_name, table_name, column_name, column_position
from user_ind_columns where index_name = 'SOMETAB_IX'
SOMETAB_IX SOMETAB SOMEID 1
SOMETAB_IX SOMETAB SOMECODE 2
SOMETAB_IX SOMETAB "SOMEOBJ"."SOMEDATE" 3
Ww
