Im trying to enqueue a text message (size greater than 4000 ) into an Oracle Queue of message type AQ$_JMS_TEXT_MESSAGE. As per Oracle documentation, I must insert the message into the TEXT_LOB field of the object if size is greater than 4000. I have tried using the following Delphi code:
Running the above code, I get the following error message if I try to enqueue a message greater than 4000 bytes.
For smaller messages, enqueueing work without a problem.
I have also tried using the set_text procedure of AQ$_JMS_TEXT_MESSAGE to set the message using the following delphi code
But this raises exception with the following message:
FYI: Im using Delphi5 + DOA 4.0.6 + Oracle 10g (10.1.0.2)database
var
myMsg: TOracleObject;
myMsg2: TOracleObject;
myText_LOB: TLOBLocator;
msg2send: String;
// Try to connect, create the queue objects, and start it if necessary
if not SendSession.Connected then
SendSession.LogOn;
myMsg := SendQueue.Payload;
msg2send := SendMessageEdit.Text;
if Length(msg2send) > 4000 then
myMsg2 := myMsg.Reference.Pin(poAny, plNone);
myText_LOB := myMsg2.LOBAttr('TEXT_LOB');
if myText_LOB.IsNull then
myText_LOB.SetEmpty;
myMsg2.Flush;
myMsg2.Refresh;
end
else begin
myMsg2.Lock;
myText_LOB.Write(msg2send, Length(msg2send));
myText_LOB.Trim;
myMsg2.SetAttr('TEXT_LEN', Length(msg2send));
myText_LOB.Free;
end
else begin
myMsg.SetAttr('TEXT_LEN', Length(msg2send));
myMsg.SetAttr('TEXT_VC', msg2send);
//Send to queue and commit
SendQueue.Enqueue;
SendSession.Commit;
Project xyz.exe raised exception class EOracleError wit message 'OCI-21710: argument is expecting a valid memory address of an object'
myMsg.CallMethod('SET_TEXT', ['PAYLOAD', msg2send]);
'Overloaded methods not supported:SET_TEXT. Use a PL/SQL block instead.'
