Marco,
This is another problem with the hierarchy pane.
1. Place the cursor somewhere within the comment;
2. The hierarchy pane should show: Code section -> Block -> Code section -> Comment;
3. Click "Comment" to select some text;
4. Delete the comment block;
5. Hierarchy pane will show correct info: Code section -> Block -> Code section;
6. Navigate with the down arrow;
7. Hierarchy pane will show: Code section -> Block -> Code section -> Select. Note there will be no changes until we you get to the assignment line. Also note the command above the cursor is not a select, it is a statement.
Regards,
Gustavo
select sysdate into vd_date from dual;
a := 1;
asd sadf
sdf
fds
fs
df
a := 1;
select a into b from dual;
Regards,
Gustavo
