HELP: Loading BLOBs using PLSQLDeveloper
Lampy
I got this task of importing a few hundreds of images into existing rows containg empty blob column. Each row contains field FILENAME so I can determine which image to load into each BLOB field.
Usual way of doing such things involves loading images onto server and then using oracle DIRECTORY and DBMS_LOB.
Unfortunately I cannot do that. Loading the files onto the server is not an option, I must do it directly from client.
One option is to write an one-off prog that will connect to oracle server, SELECT xxx FOR UPDATE the BLOB and then load blob from files.
What I'd prefer is not writing such one-off program from scratch but use some existing tool that can already load blobs from client machine. PLSQLDEveloper can do it, but only one file at a time and with user interaction.
Is there some way of scripting/automating this PLSQLDeveloper blob loading functionality?
The traditional way of doing this is installing sqlloader on the client and then using that. However you may spend more time learning to configure sqlloader than you would just writing the one-off program.
