Hi all,
Not sure if it's appropriate to make the first post an off-topic one, but honestly PL/SQL Developer has been such a handy tool over the past months while I've been developing packages, that I don't have much in the way of a wishlist or bug report
I've been using PL/SQL Dev quite happily so far to edit packages and create/edit tables, but the time has come to actually finalise the documentation, and I'm short of any good tools to produce a comprehensible database diagram.
Do any of you know of a package, hopefully around PL/SQL Developer's price range, which is capable of reverse engineering a database into a nice diagram?
I'm really only chasing the same level of complexity as you'd find in the diagram editor provided with MS SQL Server - something I can use to quickly and attractively demonstrate a database layout, without having to fudge around and create the model from scratch. Some control over colours and fonts would be nice.
In another project here, there's a database consisting of around 150 tables, whose diagram has to be manually edited in Visio to keep it in sync with the database. It would be nice to find a tool I could recommend to these guys also.
So far the closest RE tool I've seen is one named CASE Studio (www.casestudio.com), but at 349 USD it's far too expensive to justify a personal purchase, and not quite essential enough to try and justify the purchase to our bean counters.
Does anyone have any suggestions?
Nathan
Nathan
